loading
If you ever wanted to know how to install, inflate, or just get that tubeless radial Wheelbarrow tire to work with you - then this is how you do it!
This is a great tip - for a hand truck, you may need to wrap the strap around a couple times to accommodate for the smaller tire size/amount of strap needed to tighten.  Thanks so much!
Thanks. I have a dolly (hand truck) with two flat tires I have been unable to fill because they don't seal on the rim. Now I know how to do it.
Nice tip, last time this happened to me I just went and bought the matching tube size. Next time I won't have to.
Thanks. I do not own a wheelbarrow and had never thought about this. Chances are, I will run into something similar in the future and now I will know how to do it.
About This Instructable
11,436views
4favorites
License:
More by bmerritt5:How to drill a clean hole through tile - porcelain, clay, glass, hard tile How to Sweat Solder a brass/copper pipe and couplings How to charge a 12 volt battery using Solar Power
Add instructable to:
