How to install Fedora on a USB flash drive with persistence install! by Se1f_Destruct
Step 1: Get Fedora
Here is a picture of what ISO you should be downloading.
The first thing that you are going to need is the ISO, the disk image that contains all the files for Fedora to run. You can get Fedora here and save it to an easily accessible location. Just make sure that the image is up to date and that you select 32bit. We wouldn't want to use 64bit because we are striving for portability here, and many computers are not 64bit compatible, so use 32bit (unless you know what you are doing, or only want to boot the flash drive on 64bit machines). Alternatively, you can get Fedora through a bit-torrent client, you can do so by going here and clicking on Fedora Desktop Live Media i686 - Live CD. The tool we will use later has the option to download Fedora, but I do not recommend using it, as it has not worked well for me in the past.
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
