Do you have some ugly carpeting or dated linoleum flooring? Now's the time to update and the effort will really pay off. You will likely need an entire weekend to do this........................the project goes a lot faster if you have some help............. The tools and supplies you will need for this are of course the flooring (try to but the middle price range flooring as it is easier to install), a box-cutter knife, hammer and block of wood, a drill with screw bits (of course some screws 2" work well) , some underlay material, and the most important item I swear I would never do another floor without is a laminate cutter, we rented ours for $30 from Windsor Plywood and it saved a bunch of time and did not create dust. Also a jigsaw is helpful if you have curved cuts to be made and some wood glue. Total cost was approximately $500...
Step 1First Step..............remove the carpeting
I do not have a picture of the carpet being removed, but I have a few shots of the pink carpeting that was there before...............Not a pretty sight. I found it easier to cut the carpet into pieces and roll them up before disposal, the garbage-men had no trouble taking care of that for me. Another thing I might remind you of is to screw the floor in where there were some squeaks, I had the neighbour-kid walk around with a felt marker and put happy faces on the squeaky spots. Just be sure to hit the joists unlike my first attempt...Also don't forget to take off the baseboards and label them and put aside for later.
http://www.ExpressFlooring.com/laminate.php
If you are working where one measure the other cuts it sure speeds the process up, also if you rent the laminate cutter this saves lots of time (and dust).
I don't know if you could laminate over cork flooring however we did put thicker sticky tiles (purchased at Home Depot) down over a lino floor and grouted it and the results were quite nice. Three years later we have no problems with loose tiles of flaky grout so I am quite happy with this. Also we used the laminate cutter to trim tiles where we got off centre, the flaws are virtually invisible.
P.S.The handle was fully extendible!?
Now I look at the pictures I can see what you mean.
Wait until I tell my husband, I'm sure neither of us knew that!
[URL=http://i16.photobucket.com/albums/b40/jerkmonster/DSC_0065.jpg][IMG]http://i16.photobucket.com/albums/b40/jerkmonster/th_DSC_0065.jpg[/IMG][/URL]
Now here is the image of a correctly poured SLC.
[URL=http://i16.photobucket.com/albums/b40/jerkmonster/DSCN0355.jpg][IMG]http://i16.photobucket.com/albums/b40/jerkmonster/th_DSCN0355.jpg[/IMG][/URL]
Sorry for the long winded posts, i just don't want someone to get ripped off and since this is how i make my living i thought i could help people out. I have never had to go back to a job to fix anything. This is how you get more work, you don't get more work by messing up peoples homes! I do every job like its my grandmothers house. I take pride and i try my best. Hope some of this helps someone out, any questions feel free to message me.
