loading
Step 7: Install Mavericks
Continue, and you will eventually come up to a page that asks you for a "destination" for your Mac install. Select the hard drive that you want to install OS X Mavericks on, and continue (this step is shown in the first picture).
If you're installing Mavericks on an empty hard drive, the hard drive selection box will be blank. You'll have to erase that hard drive with Disk Utility first (check out Step 4 of my Snow Leopard installation guide for more details) (which I will post soon).
Otherwise, select the hard drive you want to install OS X Mavericks on, and click "Install". Mavericks will now install itself. This will take at least 30 minutes.
Restart. If your Hackintosh already had Mac OS X Snow Leopard, Lion, or Mountain Lion installed beforehand, you can unplug the Unibeast USB drive. Otherwise, keep the USB drive plugged in. At the boot screen, you'll see an icon for the hard drive where you installed Mavericks. Select it (use the arrow keys on your computer) and press "Enter" (this step is shown in the second picture).
If everything works properly, then Mavericks will boot. Mission accomplished!
The final screen is shown as the third picture.
Once again, if you get a kernel panic/loading error when you try to boot your new Mavericks installation (or if the installation simply won't start within 10 minutes), you'll need to enter some boot flags.
To enter boot flags, manually restart your computer by pressing your computer's power button. Then, once you've booted back into the Unibeast menu, try type any necessary boot flags (I will post a guide about it soon) before pressing the enter/return key. Check out this list of common boot flags (I will post a guide about common boot flags soon) for reference ( PCIRootUID=0 and -x are two popular boot flags).
<p>After I click the continue on the verify installation page, It doesn't respond.</p>
<p>hi can i uninstall unibeast in usb when i'm done using it</p>
<p>Gigabyte Rocks!!!! \m/</p><p>for everyone, you can try this tutor video to optimal bios uefi&hellip;lets see https://www.youtube.com/watch?v=7YR-DdWIZzM</p>
<p>I want to install Mavericks, but currently I'm on Yosemite so I can't download Mavericks from the App Store. Is there any other way to download Mavericks?</p>
<p>Hi,</p><p>According to your instruction, I tried many things to install on HP USDT PC (800 G1 USDT) but all of them are failed. PC auto restart when loading System.kext (I saw it in verbose mode). How can i resolve this problem.</p><p>PC specification: </p><p><a href="http://www8.hp.com/h20195/v2/GetDocument.aspx?docname=c04123137" rel="nofollow">http://www8.hp.com/h20195/v2/GetDocument.aspx?docn...</a></p><p>I make Mavericks installation USB with Unibeast 5.0.2.</p><p>Thanks so much.</p>
<p>hello</p><p>i have asus g75vw gaming laptop</p><p>intel i7-3630QM CPU 2.40GHZ</p><p>64x operating system</p><p>1TB hard drive</p><p>and 16GB RAM</p><p>can i install mavericks on my laptop?</p>
<p>Hello, do you have plans to post the PC compatibility guide? Or alternatively, where can I get one? thanks.</p>
<p>I don't have HPET option in bios settings. What should I do?</p>
<p>You don't necessarily need it. Just continue with the other settings.</p>
How can i do this if i have no Mac, just PC? <br> <br>Thanks
In step 1 (requirements), I've mentioned that you need - A Hackintosh with Snow Leopard/Lion/Mountain Lion already installed, a real Mac, or a Mac OS X virtual machine: Unibeast is a Mac app, so you need a computer with Mac OS X to run it. You could use a real Mac, if you own one. Alternatively, you could install Mountain Lion on a virtual machine (which I will post soon), and run Unibeast on there instead. Be sure to install the Virtualbox Extension Pack to view USB drives from your virtual machine. You could use one of my other two tutorials to run Mac OS X on a virtual machine then run Unibeast on this virtual machine then make this one!
so basically tp make your hackintosh, you have to have other hackintosh or apple computer at your disposal ? i better go virtual machine root
Yes! It's 95% of the time, a virtual machine, it's fast and easy to make.
About This Instructable
265,972views
60favorites
License:
More by Omar Amir:How to install OS X Mavericks on your PC with Unibeast How to install OS X Mountain Lion on your PC with iAtkos How to Run Mac OS X Inside Windows Using VirtualBox
Add instructable to:
