loading
Step 6: Step Six Cutting The Flooring.
I tipped the blade about 5 cranks from center so it was undercut slightly and that gives me a tighter fit at the surface.
The I routed a groove in the cut edge Because of the pattern on this floor I had to do that a lot. Bamboo smells a little bit like Pot when cut... Just FYI
I found a tip that you can take paint sticks for 5 gal paint cans and cut them into strips and use them for splines on your strip flooring. These fit into the slots cut by the .25 grooving bit making a instant tongue in the board.
Bamboo is indeed remarkably sustainable and stylish product, it can use as flooring because of its durability. It has a natural, contemporary look that's hard to beat. Not only is it hard-wearing and environmentally friendly, it adds character to a room. I will save these beautiful bamboo installation tips for future projects with <a href="http://www.carpetmelbournedirect.com.au/" rel="nofollow">bamboo flooring melbourne</a>&nbsp;projects! Thanks! <br>
really nice job.... highest marks on the inset border!
me encanto muy buen trabajo, voy a empezar a hacerlo en mi pieza
Gracias Por favor, disfrute el proceso.
What a great 'ible! Thank you so much for sharing. I just redid a small linen closet with shelves and now I have to work on the floor, it has contact paper with a wood grain on it and it sags! I think I will do this, even if it's a much smaller scale, it will look so good. I can't bear to tear up what is there for fear of what is under, so I will just put the bamboo on top.
I am sorry to say this... but.... you should rip it up and get down to a solid surface. Covering it up won't fix the problem and it can get worse... There is nothing to fear. I have fixed a rotten floor and it isn't any more difficult than putting down a hardwood floor. If you buy a box of flooring you might end up with more than you need.. You can make shelves out of flooring as well.. It would be cool for the floor and shelves to match.
You are right but I am scared of what I might find underneath... I will leave it for the next boyfriend in my life.
I don't want to know what happened to your last boyfriend. If you do rip up the floor and subfloor, put down two or three sheets of plastic over any bare dirt before putting the sub floor back down. I talked to my father about this and the answer was moisture from a bad roof, leaky pipe or damp crall-space. All need to be fixed right away.. Good luck.. I love looking at the bones of an old building...
Maybe Ninzerbean and Blackdog Barker should hook up. He could be her new boyfriend and him and his Dad could fix her floor, make her shelves and help her get rid of the bones. ....to the building.
Uhhhh Right.... I don't think my Partner would like that all that much.. We might have too many bodies for any wood floor to cover up.. I can see the real-estate agent now. &quot;Hold your breath and look at the lovely new floors..&quot; A new Idea for a Ible.. How to get back on topic while being funny and not turing people off..
Now that you mention it, and even if you don't want to know, it may be the last boyfriend that is causing the dampness in the crawlspace, gosh, I thought by now he would be dried up, I will look into this right away. Don't mention this to your father, please. It seemed like a good hiding place at the time though... and I too like looking at the old bones of a... oh yeah, a building.
Blackdog Barker is right. If you still have fungus or something like that down there, it will spread unless rooted out completely.
I recently put Oak flooring in my living room. I power nailed it, but did hand nail a few parts - the first 3 rows, the last two and around the floor registers. A friend gave me the tip that you can use a nail in a drill to drill with. I used the proper fluted flooring nails. You just snip off the head so it fits into the drill chuck without any wobble and drill away. It easily drilled as well as a proper drill bit. I preferred this as I found that its easy to snap the drill bits as they`re so thin.
Yes you can use a clipped nail but I find that makes the hole a little loose and nail you drive in is a little loose.. This caused a squeak... I have 3 spots in my floor that squeak and that was one of the spots in my floor I have trouble with.. Oak might be different and you might not have the problem on the edges, but I do....
Oh how I wish the idiot that installed my parents bamboo floors had seen your instructable!! I know it isn't nice to call him an idiot, but if you saw the job he left for me to fix you would call him that or worse. I have only done laminate floor installs, so this was a good review for me on what I need to change up in installing (or should I say re-installing) their floors! Thanks for sharing the info!
I have done a lot of different floorings before doing this one. I found it no harder than vinyl or &quot;engineered&quot; wood flooring. There are little things with each but I was quite nervous about trying it but there was no reason to worry. The key was to take your time.. If you run into a problem look it up on the internet... (not kidding I found all the answers to my questions.)
NIce looking job. More power to you. We just ripped out all the carpeting in our house and installed wood floors, but we had it done for a small fortune. It's hard work. I also appreciate some helpful comments from the readers. My husband and I are just finishing a stone walkway. I should have done an Instructable on that.
Tx.. My partner would have preferred to have some one come in and do it because I took so long in finishing it. We did save a lot of money doing it our selves but it takes a lot of time. (It cost about 1/10th of what it would have)
Love the contrasting color of the two styles you chose. I have installed this type of flooring a few times but just did it plain and simple, the look is quite amazing when you take some time to lay it out!
If you do this for a living you don't have the time like I did to play. You should play with the stuff before you put it down.. Go The Extra Step and Have Fun
Nice. I had particle board for underlayment, and bamboo is prone to split if you don't predrill the holes, so I chose to float ~400 sq. ft. of solid bamboo instead of trying to nail it into the particleboard. It worked well and has held up well for 3 years now. Basically you nail a starter row, lay some thin foam down, glue the tongue and groove, and use webbing straps to clamp it together until the glue dries. I scored some nice bamboo off of craigslist, but I also rejected a lot of samples. You can't really rely on the advertised hardness test; better to get a sample and try to dent it with your fingernail. The good stuff won't dent.
Bamboo doesn't swell like wood, but you do get a little bit.. I did try floating a section but the board rub together and squeak.. Glue would help but nails work well too.. and when you hammer in the floor it drives the joints together. You are correct about the soft bamboo. But I got a great supplier here and he knows his stuff so I didn't have to go thought all the problems you did..
the map is the past earth, that is canada?<br> nice project!
No it is a real place.. and it is a navigational chart... Good guess though..
a pretty well made ible, for &quot; 3 A stool as well as knee pads.&quot; you can also use a stiffer pillow. it will prevent any back pains or any other pain later on.
I used knee pads shortly but they bit me behind the knees and I don't like them.. Using a old pillow or a garden pad would help, but a little pain is part of the deal no-matter what happens..
Moser Bay, North of Akhiok, Kodiak Island
Close you get a half of a prize.. It is the area inside the box I am looking for...
You're right... should have gone to the USGS site first... Olga Bay
About This Instructable
83,936views
75favorites
License:
Bio: I earned an art degree from the Art Institute of Seattle and became a official Graphic Designer and Electronic prepress expert. To add to the ... More »
More by Blackdog Barker:Fish Fire Place Mantel How to install a Bamboo Floor How to build your own iPad case.
Add instructable to:
