3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
How to install a cassette on a bike.
This is a quick instructables on how to install a cassette on bike.
Step 1Tools
tools
  • wrench
  • cassette tool
  • chain whip
Most people will need a shimano hyperglide tool, get the park one, it's $5 or so.
11 comments
Sep 29, 2009. 12:18 AMsharlston says:
could you please make a video
Jan 15, 2008. 1:34 AMtotally_screwed says:
My Shimano 8 speed HG30 Cassette does not have the shim washer between the small sprocket and the lockring.
http://techdocs.shimano.com/media/techdocs/content/cycle/EV/bikecomponents/CS/EV-CS-HG30-8I-2322_v1_m56577569830608755.pdf
The inner surface of the lockring and the outer surface of the small sprocket are radially ridged to prevent loosening.
Jan 15, 2008. 1:17 AMtotally_screwed says:
Read This BEFORE You Buy the HyperGlide lockring Removal Tool!
The tool for lockring removal of HyperGlide lockrings recommended by Shimano is the TL-HG15. However you may not need one!
If you have the TL-FW30 used for removal of Shimano freewheels. It apparently fits all of Shimano's HyperGlide lockrings!
I found this out out by accident, because I had an 8 speed freewheel on my bike and when I came to replace it, I found that these are available, but the sprocket choice is very limited because the unsupported axle leads to bent or broken axles. I therefore was effectively forced to go down the freehub and cassette route. I ordered the tool only to find it was out of stock. I rummaged in my old bike tools bin and found a TL-FW30, it looked promising tried it and it fitted!
I then googled for the part number and found this link which confirmed that it was suitable.
http://www.bikepro.com/products/freewheels/fw_cas_tools.html
Sep 2, 2007. 12:30 AMPrometheus says:
Alternative to the Park chain-whip is to have some old chain clamped in a pair of vise-grips after wrapping it around the cog (for us who are THAT poor :P). Clamp both ends of the chain, using the chain to prevent damage from the pliers. Genuine vise-grips work best for this due to their unique shape. ««Do not use this method for chain you intend to re-use»» Practice and uncommon-sense will show you the way. This is why I never throw out old chain, and I have as many chain-whips as I need. Great instructable, but I do agree that cleaning parts prior to photography does make them more photogenic and visible, however they are not terribly dirty in the first place, so I don't see why others have trouble seeing it.. In mine, I actually did the photography in reverse, after I had already cleaned the parts, and I was actually photographing assembly for the disassembly portion.
Feb 19, 2007. 12:31 PMdorxincandeland says:
I need to brush up on my bicycle lingo... I was like, "dude, why not make an iPod dock for it?"
Sep 2, 2007. 12:15 AMPrometheus says:
OMG! Winner for funniest comment to an instructable!
Feb 21, 2007. 6:56 AMVisitor says:
Some _constructive_ criticism...
The steps you documented are:
  • list tools
  • loosen lockring
  • unscrew lockring by hand
  • look at the lockring
  • put the lockring back
You have zero pictures about actually removing or installing the cassette. Please add these steps or rename/remove this instructable.
When taking pictures, turn on all lights or take the picture in a properly lit place. The lighting in your garage is inadequate. A cheap 250W halogen construction light and an old white bed sheet goes a long way.
It would be a good idea to wash the bike parts before making an instructable. The dirty parts make the pictures look even darker and make the instructable look very hastily made. First do the steps in your instructable for yourself, then wash parts and only then do the instructable for your _audience_.
May 24, 2007. 11:45 PMStepsoftheSun says:
Perhaps it was updated as a response to your comment but... Step 3's main picture looks like someone seconds away from physically removing the gears. What would a picture of removal look like other than the bike (sans cassette) on one side of the image and the joe's hand holding the cassette on the other. The lack of that picture doesn't make this Instructable weak. All the images look fine to me; the things he intended to show (use of hyperglide tool, what the washers look like, and re-tightening the lock ring) are clear. I think the bike shop background gives him a little more credibility than would a light tent. What's dirty? The cassette before removal, but you remove it to clean it up (a guess, I actually have no clue). That last sentence is awesome, a great tip for all writers. Maybe joe and I think similarly (he's flattered, I know) so this Instructable "clicks" more for me than for you...I dunno. But overall it's fantastic to see some specific, useful critiques of someone's presentation here on this site. I hope you take the time someday to delve into my projects and give some advice. And why the hell is your handle "Visitor"!? You've got the bike frame trebuchet, the most underrated project on the whole site!
Feb 19, 2007. 5:27 PMevy-wevy says:
I manages to make my own chain wip with an old wrench and some chain. It works suprisingly well. Thanks for showing all the n00bs out there what a cassette is!
Feb 19, 2007. 1:56 PMjeffreyf says:
:) I had the same issue as dorx. I thought "Cool! Maybe he's using the gears to power a cassette deck. Slow down, and the music slows down. Speed up, and the music speeds up."
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
102
Author:joe
I like to tinker with just about anything, sometimes it works out in the end. Have fun looking at the projects, try tearing something open and let me know how it goes. cheers, -Joe
