How to install a cool looking power panel in your vehicle
I wanted to share how I built a power panel in my truck consisting of:
2 x 12 volt plugs,
1 x 5 volt usb plug and
2 x 120 volt ac plugs.
Check out my other instructables here
If you like this instructable, do me a favor and shoot me a digg
This is a video podcast I made of the build as well
Step 1Materials
materials
You will need a strip of aluminum, mine was some scrap about 1/8" thick.  I chose aluminum because it is easy to work with when cutting and filing.
You will need a power inverter.  I got mine as a present so I don't know what it cost. luckily it had pop out plugs because I could not find cool ones at the hardware store.  It also had a 5 volt usb plug which I thought would be cool to use.
All vehicles are different but you will need tools to get behind the dashboard plus whatever you are mounting the plugs to.
You will need wire and connectors to attach to the battery and the from the hidden inverter to the plugs. Be sure to use appropriate gauges for what current load you are expecting.
You will also need some inline fuses and a 12 volt extension plug.  The one I got had two outlets side by side.
I used a drill, an angle grinder, a jigsaw some sandpaper and some files.
2 small bolts and nuts to mount the panel.
66 comments
1-40 of 66next »
Aug 3, 2011. 3:37 PMContainerHome says:
Thank you for your time and effort GREAT Tutorial - !!!!! You can pick one up from HarborFreight -> http://www.harborfreight.com/400-watt-continuous-800-watt-peak-power-inverter-66814.html for 30 bucks!!
Apr 28, 2011. 10:10 AMChurch1182 says:
OUTSTANDING!! I have been contemplating doing this in my Xterra ever since I bought it and saw that they already include a 12V in the back. Now I have some better ideas for going about it.
My only thought is to add more USB's. Seems like everything mobile is going to USB charging. If I get around to doing mine I'll let you know how it turned out.
Mar 4, 2011. 6:25 AMitobor2525 says:
Good idea but: Did anyone else notice that the (liquid) cup holders are a scant distance from live AC? Why are all 3 leads from the AC plugs the same color (red) instead of black (hot), white (neutral) and green (ground)?
Feb 21, 2011. 1:12 AMratoon56 says:
I agree with jeffharbert.
Feb 4, 2011. 2:38 AMwhiplash says:
my only problem with this is working with the 110 volts, i believe all the necessasary regulations should apply to any "high voltage" system wether in a car or not
acutually i do have another problem with this... it wont fit in my car :P
Oct 6, 2010. 4:31 PMcarlo$ says:
Very cool! You are Mr. Power Supply.
Jul 30, 2010. 9:58 PMorksecurity says:
Pretty, though I too would be happier if the sockets were coffeeproofed.
What I might have done differently:
I would have been inclined to leave the inverter box closed (preserving the warranty) and just design a wiring harness that plugged into it and extended the 110VAC and USB connections out to the panel. The only problem with this approach is that your inverter has a push-on/push off switch.
If your inverter had a simple toggle switch, it could be left turned on, and power to the inverter run through a panel switch -- or, perhaps better given the peak power draw, a high-current relay could be controlled by a lower-power switch circuit.  An advantage of the latter is that the switch  could be fed from accessory,  or could be a three-way which tapped either accessory or an always-on circuit, to reduce the risk of leaving the inverter drawing power when it shouldn't and running your battery down. (Same reason dome lights are now three-way, and many headlights go off when -- or shortly after -- key is removed.)
Given the pushbutton... Hm. What happens if the button is held down before/while 12V is applied to the inverter? Would that be enough to cheat it into being externally switchable? If so, rigging something to hold the button down continuously would be easy and -- again -- would probably not void the warranty.
Yeah, the motto here is "If you can't open it you don't own it" -- but if you can find a way to achieve the same result with less work and without having to open it, that's preferable.
Jul 18, 2010. 9:59 AMnubie says:
If you want panel mount power jacks you can find them in the swamp cooler parts section. They are used to connect the water pump to the swamp cooler. I don't know how cool they look, but they should be available from your local hardware store. You shouldn't need to take apart your inverter now.
Jun 29, 2010. 2:00 AMDarkshot says:
Thanks for inspiring me for my next little college project! :D I am a gadget-junky but love to create electronics (go figure). Im going to college soon and want a laptop case that not only charges my laptop but also is not a lot of $$$. After seeing your 'ible at the beginning of the contest i realized I could put this exact same principal into the portable design! Basically build a solar powered laptop case, I first need to aquire the materials/money but it'll eventually happen. Im gonna mount the same set-up inside the top of the case, except my whole top will be one whole sheet of almuminum :) Thanks again -Tvman
Jun 20, 2010. 8:11 AMtranoxx says:
if you decide you want to run wires to your gps the same way that he did MAKE SURE YOU DONT HAVE SIDE CURTAIN AIRBAGS... that would be bad
Jun 13, 2010. 9:40 AMDieCastoms says:
Very Nicely Done! I glanced over your instructable at first and spotted the line including "wood wedges, epoxy and double-sided tape" and was honestly expecting a hack-job. I was pleasantly surprised at your end result. As others have said, the aluminum panel looks very neatly done and professional. A few comments I wanted to make: I would love to see some sort of safty covers added at LEAST to the 12 volt sockets. An errant penny in one of those will quickly blow fuses. I understand your comments that you rarely keep drinks in the cupholders, but weird things happen. Child safety covers are easily available for the 110 outlets. I am curious about the cooling characteristics of the inverter. Devices are generally designed to have a specific airflow through them to be sure certain components GET airflow. I wonder what your modification of the case has changed? I am NOT saying the what you did is detrimental, just being curious. Ingenious method of transferring the template to the panel.. just cut off anything that is painted.... All in all, I think it is a really well-done build and I intend to use some of your ideas when I continue on to my own similar project in a 97 Mazda Protege.
Jun 17, 2010. 2:22 PMlegless says:
Hey Dave. Nice job by the way. With all the mention of covers for the sockets, I wondered if the original covers from the inverter might have been used somehow?
Jun 13, 2010. 12:19 PMDieCastoms says:
Thank you for an awesomely fast response!
_______________________________________
Radioshack and Walmart have carried rubber caps for the 12 volt receptacles, but if you always have something plugged into them, then they would probably be in the way more than useful..  A friend had her accessory fuse start blowing out seconds after replacement and I took her stereo out to check the aftermarket wiring..  I spent at least 90 minutes searching for faults or shorts before she told me that a cellphone charger had fallen apart inside the cigarette lighter socket.  A chrome ring from the tip of the charger was still inside the lighter socket and was cooking fuses almost immediately ......  What a hassle that all was . . .  Oh well.
In my Mazda, originally, there was a stereo head-unit at the top of the dash and a seperate CD player unit further down in the dash.  The aftermarket stereo all fits in the top location, so the bottom unit's bay as well as the ashtray and cigarette lighter areas further down will be replaced by a single aluminum panel.  A new 12 volt outlet with a rubber cover, two 110 outlets, and various toggle switches (for my amplifier, inverter, eventual neon lighting, etc.) will be located in the panel as well.
Also, I really hate that 'ible's comments do not recognize hard returns ...
Jun 4, 2010. 11:53 AMjdtwelve12 says:
Slick project. The brushed aluminum looks great. One thing I noticed from the photos was that your cup holders are right behind and above the power outlets. In my car, I often get condensation dripping from the sides of cold drinks. It might just look this way in the pictures, but I wonder if you don't risk shorting from having liquid so close to current?
Jun 17, 2010. 2:16 PMlegless says:
At risk of getting a flame warning I just have to say it. Geez give the guy a break. He mentioned that there could be problems several times. It is an instructable of how HE built and uses HIS power panel. Above all it can be considered a guide not a rule book. Most writers of Instructables assume quite reasonably I think that people are going to engage their brains before doing some stuff. I never use "cup holders" in my car.
Jun 17, 2010. 5:08 PMjdtwelve12 says:
No flame war necessary. This was a question for discussion, not a detraction. The author pointed out that he addressed my question in the video, of which I'll admit to having skipped parts. I stand by my comments that he did some slick work and it looks great.
Jun 15, 2010. 8:54 AMF22-Raptor says:
Great instructable and cool video edit. One suggestion: spray some clear coat on the aluminum to protect it from scratches and give it a cool look . If you can mix the clear coat with some black paint that would be even cooler. 2-3 layers of clear coat should be enough.
Jun 15, 2010. 5:39 AMii_awesum says:
Excellent job! I have a Dakota as well and the same needs. The dash outlet is in 100% use powering my XM rig. I opted to put a 12v Acc outlet sideways on the drivers side of the console to keep the drink holder accessible and just in case drinks spill I don't have to worry about getting any on the outlet. I use it to power my 75w inverter which charges my Plantronics headset. It's a bit clumsy but serves the purpose. Dodge did a poor job with storage and organizing in that truck, I might eventually do an instructable on a full center console with storage in the armrest.
Jun 14, 2010. 7:15 AMfzxdf5 says:
a nibbler would have worked great here
Jun 14, 2010. 9:21 AMfzxdf5 says:
you can pick one up from Home Depot, or simular store or any electical supply house, that is hand operated and is in the $30 range, I think mine is Klien, but it works great and anything you can put into it...stainless is kind of hard upon it
Jun 14, 2010. 7:18 AMfzxdf5 says:
should have added circuit protection here...a 30A fuse or circuit breaker (both are like a buck at fea markets in my area, i have a few on hand at all times) would keep you from having, as we say in the industry, an unexpected thermo event
Jun 14, 2010. 7:15 AMCodfishCatfish says:
Great project. If I could add a suggestion. Most over the counter Inverters are modified sine wave that cause havoc with some equipment and are unsuitable for flouresent tubes etc and cause hum on some equipment. The more expensive Pure Sine Wave inverters can cost 5 times as much. I however have discovered that nearly all APC Smart UPS system are Pure sine wave and if you can get one from eBay that needs battery replacement then you can use the car battery as the source and enjoy pure sinewave with over volt, over current and full thermal protection from a UPS that most office PC's and quite a lot of home PC's use. I have seen them go here in the UK for as little as £30 approx $50 for 1000VA and often larger rack mounted versions or 2000VA trade for less. Only a few mods are needed to convert the switching when a loss of power is detected. Hope this helps Awesome project by the way.
Jun 14, 2010. 7:00 AMmattie says:
How neat and attractive is that! Ingenious! Mattie
Jun 13, 2010. 8:59 AMchumateco says:
Well done.
Jun 13, 2010. 8:04 AMjeffharbert says:
Great ible! I've been thinking of doing this very thing myself. One thing you might consider is rotating the outlets so that the ground terminals are pointed away from each other. This would free up space to allow two space-hogging wall warts to be plugged in at the same time.
Jun 13, 2010. 7:01 AMThe Arbiter says:
I can not add much past what others have said, but very nice job and a very good instructable. I had a friend reading over my shoulder and now I have been tasked with installing something similar into her car.
Jun 4, 2010. 11:29 AMInkydog says:
Nice! You might want to consider affixing a label showing the maximum wattage above the AC outlets. Never know if someone is going to try plugging a hair dryer into the thing...
Jun 6, 2010. 6:19 PMPCfreak says:
who would use a hair dryer in a car anyways?
Jun 13, 2010. 6:59 AMThe Arbiter says:
The same people who would use it while showering, hence the "Do not use while showering labels on hair dryers" LOL
Jun 7, 2010. 6:28 AMmoorea7 says:
How about my 26" CRT TV that I'd love to have along on a camping trip? Can I plug my toaster and griddle in so I can cook breakfast too? - Plenty of opportunities to overload. This probably will not happen while you own the truck, but a future buyer might try this!
Jun 17, 2010. 2:18 PMlegless says:
This would be really easy to prevent when he sells the car by just removing the inverter. As he said he is careful.
1-40 of 66next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
97
Author:dave spencer(www.mechanicalmashup.tv)
I have had a few careers so far, soldier, school teacher, arborist, millwright. I love change and I love learning.
