Step 3Transfering the template
iImage Information
This is a cool trick I use all the time to transfer patterns. I cut out the printed template, spray it with spray adhesive and stick it to the aluminum. I spray the aluminum with a coat of spray paint. Let it dry a bit and peel off the template. You will be left with the areas you need to cut out marked with spray paint. Just be careful not to scratch the paint of when working on it later. If you do though you can repeat the process with the same template again.
