3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
How to install a cool looking power panel in your vehicle
Step 4Shaping the panel
shaping the panel
I used a drill to drill into the painted areas. Use a bit large enough to fit in a jigsaw blade.  Then rough cut the shapes with the jigsaw.  You can finish the shapes with a file so it looks nice. this is where you will be happy you chose aluminum instead of stainless steel.  test fit everything as you go along. File off all the sharp edges as well.  The small slot for the USB was made by drilling a hole at either end and using some small files to shape the slot.  To give it a cool "brushed finish" all you have to do is run the aluminum back and forth in a straight line over some medium grit sandpaper.  I think I use 220.
1 comment
Jun 14, 2010. 7:15 AMfzxdf5 says:
a nibbler would have worked great here
Jun 14, 2010. 9:21 AMfzxdf5 says:
you can pick one up from Home Depot, or simular store or any electical supply house, that is hand operated and is in the $30 range, I think mine is Klien, but it works great and anything you can put into it...stainless is kind of hard upon it
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
101
Author:dave spencer(www.mechanicalmashup.tv)
I have had a few careers so far, soldier, school teacher, arborist, millwright. I love change and I love learning.
