3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
How to install a hardwood floor.
  • last photo ←
My house is over 120 years old so I figured that an upstairs bedroom was long overdue for new flooring. Especially since it only had the old tongue & groove sub floor rather than nice hardwood or carpeting. In this Instructable I will go through the basic steps necessary to install a new hardwood floor. The tear up of the old subfloor took about 7 hours with the help of my wife. The installation of the new plywood subfloor took about another 4-5. The new hardwood I installed alone which took a weekend and a few hours on 3-4 weeknights. If you have someone to help through the entire project it could easily be done in a single weekend depending on whether you need to install a new subfloor or not.
I used the following tools & materials to complete this installation:
All costs are rounded up.
Hammer
Pry Bars
Compound Miter Saw
Circular saw
Cordless drill
Pneumatic Floor Stapler with 2" Floor Staples $120 total - rented
18 Gauge Pneumatic Brad Nailer
18 Gauge 2" brads $6
Air Compressor set at 100 psi
54 feet of 3/4" Pine Roundover trim $40
Approx. 180 Sq Ft of 3/4" prefinished oak flooring $525
5-1/2 sheets of 3/4" pine plywood (subfloor) About $90
1 box of multipurpose screws $10
Step 1Tear up old subfloor.
This may or may not be required depending on the condition of your existing sub floor. As I said, mine was tongue & groove meaning that the edge of one board fit some what tightly into the adjoining one. However the floor was quite uneven from years of wear and most of the boards were quite loose so I chose to remove all of the old boards and replace them with 4x8 sheets of 3/4 inch plywood. I used a circular saw to cut along the edge of the floor with the blade set at a depth just deep enough to cut through the boards yet not the floor joists. I also used the circular saw to cut the 4x8 sheets of ply wood to size.
20 comments
Apr 28, 2011. 8:26 AMegdinatale says:
One note, I'm pretty sure you're supposed to leave a small gap from each wall to allow for expansion and contraction as the seasons change. Otherwise, looks great!
Aug 24, 2010. 2:40 AMmard1kas says:
One tip I have heard is that you should install the flooring so, that the panel joints run from the window to the room. This apparently makes the room lighting better.
Jul 18, 2010. 5:38 AMbiker_trash_1340 says:
Looks great... Just some tips /// I work at a "Big Box Tool Rental" Get your wood and let it sit in the room for a few days. Let us know the thickness of your wood, better yet bring a piece in with you (most are 3/4) We can shim the gun or give you shims to fit your wood. Never tap / hit the gun with the steel end of the hammer!!! That will drive up the cost of your rental by $150.00 for replacement parts. (they have to work for the next guy)
Jun 27, 2010. 5:41 PMjamiechandler says:
Did you PL the subfloor in addition with screws? This helps prevent creaking to the nice hardwood as the house continues to move and settle.
Jun 14, 2010. 10:11 AMtok2 says:
speaking of personal experience. Adding insulation between the floor joists below the sub-floor will not help with the wear and tear (bumpy floor) that comes through years of use but the sound proofing it will do is way better than the cut you'll get to your heating bill; if you have teenagers or noisy kids in the house that is. I've never tried nailing the floorboards down before, but if i ever make my own I'll definently think about it if no easier alternatives arise.
Jan 27, 2010. 7:05 PMM4industries says:
 I prefer carpet, although hardwood floors increase appraisal value.
Not that I would know (I'm only 14).
May 26, 2009. 11:23 AMmarwanco says:
Thank you for nice video. I'm in the middle of installation, already ripped first 3 rows because they were installed parallel to joist (like you did), and started again parallel to shorter side of te room but perpendicular to joist. Is it a big problem the orientation of floor plank against joist? 2.My subfloor is uneven in some areas, and in this areas it squeeks, is it good idea to fill the gaps under planks with shims? or there is another solution?? Thanks
Jan 4, 2009. 7:32 PMvickireed says:
Curious, do you recommend 3' or 6' flooring? I'm having trouble finding the 6' any recommendations would be appreciated.
Dec 22, 2008. 4:42 PMPS118 says:
This is cool! I've been looking at trying some of that bamboo flooring, but been scared to try -- till now. I have a question tho. Is there supposed to be some kind of expansion gap left for the wood? (That's been my greatest fear is not knowing something like that, nailing everything up tight, and having the thing buckle in the summer.)
Dec 23, 2008. 9:30 AMPS118 says:
Great! Thanks for your reply!
Dec 23, 2008. 6:41 AMmuzzz says:
How much did it cost, with equipment rental and all?
Dec 23, 2008. 7:47 AMnolte919 says:
Did you mean brad nailer in the last step or is bard nailer really a thing?
Dec 22, 2008. 7:20 AMjeff-o says:
Did you use tongue & groove plywood for the subfloor?
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
25
Author:mattl(OhCripes.com)
