The kickstand should come with a bolt and a kind of top bracket, which at first glance seems not to really fit with the stand part. The only tool you'll need is a wrench - my kickstand had a bolt that a 14mm wrench fit well. An adjustable wrench would also work.
The third pic is of the part of the bicycle frame that the kickstand will attach to.
Remove these ads by
Signing UpStep 1Attach the bolt
Note also that the top kickstand bracket may want to interfere with the pedal gear shift cable! This is just bad design on my bike, but there's no reason not to simply rotate the bracket to avoid the cable. As long as there's enough bracket on the bar to hold the kickstand, you're fine.
Insert the bolt, from the top, through the top kickstand bracket, through the hole in the bike frame bracket, and into the main kickstand part. Screw it in.
17
comments
Add Comment
rachel (author)
says:
rachel (author)
says:
theRIAA
says:
rachel (author)
says:
Mr. Rig It
says:
CameronSS
says:
Add Comment
