3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
How to keep your bike seat from getting stolen.
Use an old chain and a trashed innertube to keep your seat by getting stolen. Most bike related theft is prevented if the act will take the theif longer than a few seconds. Even if they do have a bolt cutter on them, they're less likely to take your seat if they have to pull the bolt cutter out of their bag.
We learned this trick fromStreet Level Cycles at Aquatic Park in Berkeley. Support your local community bike program!
Step 1Take an old chain and measure a loop.
Remember to set the seatpost at the high end of the range where you like it.
12 comments
May 2, 2012. 8:57 PMflavien008 says:
I did exactly the same BUT with a plastic rope inside the tube!!
1) do a loop with a palstic rope (like 1m long)
2) attatch by a nail inside the top of the bike-seat-tube
3) evaluate if the length is ok but doing the same temporaty inside the bottom of the bike-tube
4) change the lenth if necessary
5) put the mail, cut it 3 mm away from the outside of the tube, hit it with a hammer
(no sound of metal, invisible, you can move and turn the seat, but not extract it while the rope is here, then you need a hammer or a saw, because the rope is ptotected by the tubes) !
enjoy!
May 20, 2009. 9:36 PMjolshefsky says:
That's a genius idea. Here I've been using vinyl-coated stainless steel cables with crimps all this time!
Apr 1, 2012. 12:53 AMbangaaking says:
I vote for the steel cables!
Jan 5, 2012. 1:58 PMUbbo says:
Couldn't you just break the chain with that same tool again?
May 21, 2009. 8:31 AMSWV1787 says:
I like this alot, but does the chain swaying behind you while riding drive you nuts? I think it might me...
May 23, 2009. 11:23 AMJerryMopar says:
It shouldnt clang too much IMO with the innertube around it.
Aug 27, 2011. 4:17 AMbatvans46 says:
zap strap (zip tie) it to the seat tube.
Mar 11, 2011. 1:48 PMHallmar says:
Wonderful idea, but when i leave me bike in a bad place, i just take the seat off and then i lock it along my front wheel and frame:]
Aug 25, 2009. 11:38 AMshift_nismo says:
cant you just run your chain through the saddle when locking up your bike?
May 24, 2009. 9:19 AMSurferGeek says:
Great idea but how about this:
Replace the quick release on the seat with a tamper resistant bolt that way the only thing you need to change the height of the seat would be the tamper resistant wrench which is usually quite small and easily pocketed.
Example:
http://www.brycefastener.com/about.htm
Either way, your's is a nice solution but I wouldn't like the added weight and the annoyance of the chain bouncing around.
May 21, 2009. 12:53 PMYambo says:
If the problem is caused because you have a quick release seat, why don't you just take the seat with you?
May 22, 2009. 6:55 AMjeff-o says:
It's cumbersome, and sometimes you just don't have the room to carry it with you. Plus, there's a chance you'll forget it...
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
13
Author:fossilfool
Fossil Fool, the Bike Rapper, a San Francisco street performer and bicycle entrepreneur. Invented the Down Low Glow, a neon safety light for bicycles. Develop high-end sound systems for bicycles used ...
more »
