How to kick start a motorcycle.
 by pulsed
Contest WinnerFeatured
Step 5: The beast.
If you have a larger bike like a 200 or 450 (the honda 150r also applies) The bike ma have a hot start.Basically it reduces compression so its not as hard to start.On the 450 you couldnt start it without the hot start.So follow the same steps as the othe bike but while kicking the bike hold thee hot start until it fires up.It should be located over the clutch.Ride safely and have fun!
indian741 says: Feb 25, 2013. 3:20 PM
Never used this lever ,
I always kickstart without this,
I got a suzuki drz400 and a Armstrong mt500
Just get the piston to TDC ( the part where u hear it click )
Then 1 hard kick and i should run without this lever .
muddog15 says: Dec 28, 2012. 12:06 PM
will this work on a hard to start go kart?
takboilaw says: Sep 25, 2011. 6:28 AM
I have a kawasaki 125 it has both electric starter and kickstart. I has a choke level on the handle bar and a kill swith aside from the ignition switch. I usually kickstart it when the battery become low due to my motorcycle audio(it drains the batteries charge)
Scott_Tx says: May 28, 2011. 6:19 PM
This instructable needs a video to go with it! :)
whipit85 says: Nov 24, 2008. 3:53 PM
a hot start doesn't lower compression, it lets cool air into the carb, rather than the warm air from the heat of the bike, the cool air cool the cylinder enough to that it starts easier, when the motor is cool they serve no point.
wobbler in reply to whipit85May 17, 2011. 5:43 AM
A hot start doesn't let cool air into the carb rather than hot from the heat of a bike air. The air to the carb is always coming from the same place. What a hot start does is vary the richness of the fuel entering the cylinders a appropriate for starting a hot engine and actually adds more air to the mixture, making it more lean. A cold engine requires a richer fuel mixture to start (hence the choke lever). The hot start lever is like a choke in reverse.
However, big bikes, especially big single cylinder bikes, are hard to turn over as at the top of the stroke there is a lot of back force from the compression in the cylinder. So, big bikes have compression release levers, which lift the exhaust valves slightly and make it easier to get the piston to the top of its stroke. The lever is then released and the bike then kick started from the optimum position..
2hot2hack says: Apr 25, 2011. 9:47 PM
nice tips. my sister got me a yz125 (2010) to ride at her house but she moved and it rusted.
Acepilot42 says: Jan 11, 2011. 1:04 PM
cr 500's have that lever too
miniminitrck says: Oct 2, 2009. 7:13 PM
Thats not a hot start anyways, its a compression release, and it is a very handy thing to have when you have a large bike
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
