loading
Step 8: Row 28
Purl all the way across.
At the end of the row, cast on 5 stitches (see screenshots showing casting on the first stitch and then what it looks like after all five are cast on).
Great pattern! This is only my 2nd project ever and it took me 2 days to complete both gloves. Will definitely use this pattern again, but will probably adjust so they fit more snugly to my wrists.
Step 20 not sure where to place stitches. Is it the edge where castoff stitches are?
<p>Hi mgrandamil,</p><p>Yes, it is the outer-most edge of the thumb wrap. Hope that helps.</p>
<p>I had a bit of trouble figuring out where to leave room for the thumb part, but I figured it out and ended up with a great glove! Now to work on my next one... </p>
What is the correct tension?
<p>Hi Annie,</p><p>Everyone holds their yarn at different tensions. Generally speaking, I would recommend you not hold the yarn too tight, or the gloves will be smaller than expected and you won't be able to get your hand in. But you want the tension to be firm enough that the stitches aren't so loose that they are flopping up and down the rows. You can also read through the comments others have posted here, and that may be helpful. Thanks for checking out my pattern.</p>
<p>Thanks for pattern. Cold as,here in N.Z.now so about to try your lovely pattern.</p>
<p>how do I verify my account (I'm new)</p>
<p>Thanks! I made a pair for my little sister for Christmas. She wanted them similar to the ones worn by &quot;Ahsoka Tano&quot; in &quot;The Clone Wars&quot; so I made them a bit longer, and exposed the fingers a bit more.</p>
<p>Love your work! I had to adjust the tops also!</p>
Thanks!
<p>These look great! You chose my favorite color, too ;-) Thanks for sharing your pic!</p>
Thank you! Glad you like them!
What is the gauge for this pattern? I would like to figure out how to make these with smaller needles and a lighter weight yarn. Thanks.
<p>Sorry but I don't know how to figure out the gauge. I'm an advanced enough knitter to improvise and make this pattern, but not advanced enough to give gauges for different weights of yarn.</p>
<p>I've used this pattern to make Christmas gifts for my family and it works perfectly!</p><p>I've since edited the pattern slightly to make a cabled version with moss stitch palms, I hope you like them!</p>
<p>Wow! I'm impressed! Very, very nice job!</p>
<p>Thank you very much :)</p>
Just finished this pair, two hours each! Made using 24 stitches, worsted weight Red Heart yarn on size 8 straight needles! :-)<br>
<p>Awesome! They turned out perfectly! Nice job... and nice pic!</p>
Made several pair on several colors, everybody loved them !!
<p>Super! I love the variety of colors and pairings you did with the buttons, textures accessories. Thanks for posting the pics!</p>
<p>I made a pair of fingerless gloves for my friend, but it seemed too big for her. (26 stitches) Can I knit with 22 stitches and a bit less ribbing at the top? Thanks ~</p>
<p>Yes, you can adjust the number of stitches, but I don't have an exact gauge to give you because the weight of the yarn and how tightly you stitch varies from person to person. But feel free to add or remove stitches -- I just recommend you take note of whether you've casted on an odd or even number of stitches.</p>
<p>One glove down! This was my first real knitting project and I don't think it came out too shabby. I lost track of purls and knits somewhere in the middle but it adds character, right? </p>
<p>I think you did a wonderful job, and the extra texture looks like it was meant to be. Thanks for trying out my pattern!</p>
You did great. I'm about halfway through my first glove and I had to read all the way through. I think you did great.
<p>As it is currently winter here in Australia these gloves are amazing I love them, I made a pair last year and am now in the process of adapting this basic pattern into convertible mittens, to match a beanie I recently knitted.</p>
<p>Instructions detailed and accurate, thank you! The only thing I would say to prospective knitters of this pattern is to measure for size. I did the 24 stitch cast on and it was WAY too tight for me, plus the glove part went way past my fingers. There is room to customize here and don't be afraid to do so before you finish. Its sad to finish a project you can't wear!</p>
<p>can't get my image to load, any clue?</p>
<p>yay I am almost done all I have to do is sew :D yay!</p>
<p>This is a cool gift for a birthday. I am doing this for my mother and I am a beginner at kitting and this really helps a lot better then those store bought books. :)</p>
<p>Do you tie off the yarn at the end? Or does the &quot;weaving back through about three inches&quot; keep it from unraveling? Thanks!</p>
<p>Hi sparks_mcgee,</p><p>No need to tie off the end. the weaving through keeps the yarn in place. Hope you had a chance to make the gloves and had some fun with it!</p>
<p>Hi, I have a skein of sock weight yarn that calls for size 1-2 needles. Can this pattern be adapted for thinner yarn? I am a beginner so I wouldn't have the slightest clue in making the adjustments myself. Thank you!!</p>
<p>Hi Kathryn,</p><p>No - this pattern is not suitable for sock weight yarn. Sorry, but you need worsted weight, or equivalent, to keep the gauge correct.</p>
<p>I am on row 28 and have pulled across. Need to cast on 5 but my work shows the knit side. How to I cast on as can't tell by pics? Thanks!</p>
<p>Hi Sue,</p><p>After finishing row 27, you should be seeing the &quot;wrong&quot; side of the work. If you do not, then perhaps the row count is off. Your solution to knit across is actually what I would recommend, OR, you could rip out one row, but it is easier (if you are a beginner) to simply knit another row than to try ripping and risk dropping stitches. Then, you can proceed with purling the next row and that will keep you in synch for the rest of the pattern.</p>
How to cast on:http://m.wikihow.com/Cast-On<br>I'm having the same problem with my work showing the wrong side. I'll let u know if I figure it out.
I finally just knitted across and adjusted rest of pattern as I went.
<p>I am confused. I am on step 11 row 34. Instructions say to cast off the first 5 purl across. If I cast off the first 5 it will be one row less than the other side because it wasn't the first 5 cast on. I know I have the right number of rows. Please advise. Thank you.</p>
<p>I came across this pattern while searching for simple fingerless gloves. I was making a hat, scarf set and wanted to add some gloves for my daughter-in-law, but had never made gloves before. These were so simple! They came out beautifully! I can't wait to start on mine. No pic as I feverishly worked on them to get them finished for Christmas (Santa was up to 1am finishing and wrapping)! Thanks for a great pattern. As soon as I get my DiL to send me a pic, I'll post back.</p>
<p>I made some of these for my daughter. She loves them.</p>
Thanks for the tutorial, I am working my second pair right now
<p>Hi, I am a beginner in knitting and am struggling to finish row 28. I did purl all the way across but I do not know how to cast on purl stitches at the end of a row. Could someone please help me do this or perhaps direct me to a video.</p><p>Thank you very much.</p>
About This Instructable
918,242views
565favorites
License:
More by plzsendchocolate:Knit cables! Fun and Functional Cat Litter Box cover Turn your picture into Pixel Art
Add instructable to:
