How to light a coal fire
 by lemonie
Step 5: Light it!
Ensure the fire-front is removed for maximum air-flow, ignite the paper from underneath, and in multiple places - get as much of it lit as quickly as possible, as heat will feed between ignition-points (particularly if the paper is not the dryest)
If you've built this correctly all you have to do now is leave it for 30 min.
Coal needs time, the fire will blaze nicely while there's wood and paper left, but all that cellulose-fuel needs to heat the coals enough that when it's gone the coal-fire is self-sustaining. Coal produces gas and tar when heated only when it's "dried out" do you get the red-hot (or brighter) 99% carbon fire that makes coal so hot.
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
