Remove these ads by
Signing Up
Remove these ads by
Signing Up
Remove these ads by
Signing Up
PDF Downloads
As a Pro member, you will gain access to download any Instructable in the PDF format.
You also have the ability to customize your PDF download.
"Or you could just unplug it, but that would make it very clear that you know they're spying on you."
Wouldn't they get suspicious when you "further inspect" any place where light was bouncing off? If they're looking at the monitor(s) while you're looking directly at the camera, I'm pretty certain they're gonna know you know.
Unfortunately, there's almost no way you're gonna be certain that someone isn't "watching" you (other then painting everything over and buying new furnishings).
www.wikihow.com/Build-a-Hidden-Camera-Detector
Fear breeds watching.
So if you find a camera take a photo of the room and extend that photo
from the wire in front of the camera...the watcher will think the room is always empty till it dawn on them the room is always sunny never gets dark
HA
Sad...Sad we have to live like this I wonder if we are all stressed because we do feel this way. Living in a culture that is always wondering what people are doing.. Here I will show you * picks nose*
O <----l==l
Big brother is watching you...
*nervously looks over shoulder*
the thought police are everywhere...
http://cart.eyespymagusa.com/index.php?p=product&id=222&parent=22
"Hand-held Covert Video Camera Detector
The SpyFinder hidden camera detector/locator is the most reliable and popular technology on the market. Its function is based on the principle of optical augmentation. This refers to the phenomenon where light reflected from a focused optical system, such as a video camera, is reflected along the same path as the incident light. This means that if a hidden camera is illuminated and viewed with the SpyFinder technology, then a strong flickering reflection from the target camera reveals its position to the user. The SpyFinder exploits this phenomenon by using a ring of ultra-bright LEDs arranged around a viewing port.
When a user scans a room looking through the viewing port, a hidden camera appearing in the field of view will brightly reflect the light from the LEDs....
Simply look through the viewing port (see photo) and depress the button to activate the LEDs. Slowly scan areas where hidden cameras are suspected and look for bright reflected spots. Remember, most hidden video cameras use pinhole camera lenses, so the spot you are looking for could be small. If you see a suspected camera, move your vantage point slightly. If the location of the reflection moves as you move, then this is not a camera. If the location of the reflection does not move, then it is highly likely that you have discovered the optics of a hidden camera. For example, consider a wall clock that has a domed plastic cover and a pinhole camera concealed under the numeral six on the clock face. When the SpyFinder is used to scan the clock, a reflection will be noted where the camera is located beneath the six and a reflection will also be noted from the plastic cover. However, if you move your vantage point just a little, you will notice that the location of the false positive reflection point from the plastic cover will move, while the reflection from the camera remains under the numeral six on the clock face."
