Introduction: How to Made a Cheap Homemade Water Filter
Picture of How to Made a Cheap Homemade Water Filter
Muddy water may be the only water you can find so, knowing how to make a water filter is important. There are a lots of different ways to make a water filter. The simplest and cheapest way is to use sand. Sand is natural way of filtering water.
Simple sand water filter
1. The first step to begin with, you will need to find a large container. Find a large, empty can, use it. Put about 8-10 holes in the bottom. A large plastic bottle like an empty milk carton would also work. Cut the end of the bottle off evenly.
2. Secondly, find some material you can place at the bottom as a filter. For instance:
• a couple of inches of gravel.
• a grass mesh, make sure it’s nonpoisonous grass.
• or cloth material.
3. Next add a layer of gravel. The purpose of the gravel layer is to strengthen the filter substance and help prevent sand mixing with the water you get from the filter.
4. Now, you want to fill the bottle or can with sand.
5. Finally, pour your collected water through the homemade filter. Retrieve it in another container from the bottom. Look at the water that comes out of the filter. It should be clear. If not, you may have to pass the water through the filter more than once.
Safe drinking water
Now you have made a water filter, but it still may not be safe to drink. The water may still contain harmful bacteria that your filter did not remove. To get water safe enough to drink, you also have to purify your water.
ameluc23 (author)2017-10-04
sup
asmith2310 (author)2017-10-04
hi that is awesome!
maazh (author)2015-03-28
u could also use coal (crushed) and add a cloth to hold the coal it is very affective i have tryed it
tlchico (author)maazh2015-04-30
Also charcoal like you use in a fish tank will work great.
JosephineBernie (author)2014-11-06
Water is essential for health, hygiene and the productivity of our community. water treatment process may vary on the water condition that you have in your area. its better to invest on a good water treatment. it will benefit you by providing safety to you and your family.
maazh (author)JosephineBernie2015-03-28
i like the people that are smart and always tell u more thx :)
kenzie_lu0920 (author)2015-03-25
JasonForest (author)2014-10-21
thanks for sharing us your knowledge. we really need to have a good water purification system now that millions of people are dying from different diseases they acquired from drinking unfiltered water
http://www.berkeywaterfilternow.com
emurdoch (author)2014-01-15
Can this filter work with placing water with soap in and can filter out the soap?
Lorddrake (author)2012-12-17
After you run your water through your filter, the best way to purify water is to bring it to a rolling boil and let it continue to boil for at least 1 minute ( boil for at least 3 minutes when at altitudes over 2000 feet). Boiling the water kills germs and parasites.
About This Instructable
98,376views
22favorites
License:
More by d4mharris:How to made a cheap homemade water filter
Add instructable to:
