3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
How to made travel charger for mobile telephone
We need:
Car telephone charger,
8 batteries AA or another batteries on 1.5 V (8*1.5 = 12V),
battery holder box,
car cigarette lighter socket.
2. Connect the cigarette lighter socket to the battery box ( «+» - on center). Put batteries. Connect car telephone charger to socket.
3. It‘s a very useful thing for a traveler. One set of batteries can charge Nokia N73 for 3 to 5 times.
Step 1
We need:
battery holder box,
5 comments
Mar 14, 2012. 10:14 AMfersidhe says:
Super Idea. Yes, 12V when you only need 5V is a little wasteful, however, this is fantastically easy to build. I am going to build this, mount it in a small cigar box, and use it with rechargeable batteries at weekend camping trips to charge my i-devices and androids.
May 18, 2011. 10:34 AMchriszzz says:
This will work, but does not make any sense. Why would you use 8 batteries to get 12V to charge a phone that only needs 5V to charge ? Most phones charge using only 5-6V, so you would only need 4 batteries, and a USB charging cable ( which is cheaper, lighter and more robust than a car charger ).
A voltage regulator would make it "safer", but it's probably not needed since 4 batts should be pretty safe.
Dec 11, 2010. 3:55 AMlemonie says:
It'll work but had you thought about re-building the charger to run on less than 12V? It'll output much less than 12V, but it's obviously designed to adapt from a car's supply.
L
Dec 13, 2010. 12:40 PMlemonie says:
If there's a voltage-regulator in there it may be easier than you think.
L
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:vintovkin
