Remove these ads by
Signing UpStep 1Materials
Strip of 2-sided copper-clad board. The size of this will depend on the size of your layout.
Paper. You don't need anything fancy. Just get basic gloss photo paper.
Tape. Scotch tape works fine.
Sponge. I use a potter's sponge (available cheaply at art supply stores), but any type of sponge will work.
Ferric Chloride. Available at most Radio Shacks.
Iron.
Light Box. Optional, but very useful. If you don't have one, you can make one easily, or use a window on a sunny day.
Drill Press. You really don't want to use a hand held drill.
#60 Drill Bit.
Saw.
Acetone. This will dissolve toner in a hurry.
Scotch Brite Pad. Buy a lot of these. They wear out.
Rubber Gloves. You really don't want to get ferric chloride on your skin.
Safety Glasses. Need I say more?
Ferric chloride is safe enough for disposal,such that is is, but be advised that the copper that gets etched into the solution is quite nasty. Even in trace amounts, it is poisonous to fish, and possibly other aquatic wildlife. There is an excellent instructable on the site that describes etching with muriatic acid and peroxide that lasts a long time, is fast and clean, and lets you avoid putting copper down the sink. Search for 'a better etching solution' and you'll find it. Food for thought. Oh, and the muriatic acid/peroxide etchant is CHEAP.
I had ZERO success with ANY toner transfer methods until I tried these two things together:
1) After scrubbing the copper board, drop it into the etching solution for a few seconds. Remove and rinse. Be careful not to touch the copper after it is dipped/rinsed. It roughens up the surface and makes the toner stick much better. It also removes any oils and deep-down dirt that the scrubbing missed.
2) When repairing traces with a "sharpie", roast the board on your iron for about 30 sec. to make sure the "sharpie" ink is completely dry, then etch.
I use a beat-up HP Laserjet 6L, press-n-peel blue with my iron on about 3/4 full heat and moderate pressure, and get great results. Your millage will vary. Experiment a bit. It is probably different with photo paper, but try the above tricks. Good luck!
It might be necessary to use heat-proof Kapton tape, though.
One further question, have you ever tried doing the toner transfer to both sides of the board at the same time? I've only ever done it one side at a time and it tends to smudge the side that's already done. I want to avoid that, too...
The toner transfer itself could have been better. Perhaps it was not heated enough, or some dust or fingerprints got on there. Still, I should be able to repair the board with some etch resist pen.
