3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
How to make 2-sided Printed Circuit Boards
Step 4Toner Transfer
Toner Transfer
It's time to transfer the image off the paper, and onto the board. This requires a clean board. As you can see, mine was pretty oxidized. Use a scotch brite pad to scrub it clean. Do not use steel wool. It will wreak havoc on your board. Once it's nice and shiny, rinse it off and blot with a clean cloth. Don't touch it. the oils from your skin will interfere with the transfer. Let it dry completely.
Find the side of the board that has holes that match the ones on your copper board. Line it up so that all the holes are aligned. The light table is helpful when doing this. Once aligned, tape two sides so it won't move. Heat up the iron. Put it on the hottest setting. Then iron over the paper, pushing down hard. You have to push down really hard. Do this in 30 second bursts for five to six minutes. When you're done ironing, run the board under cold water until it's cool. then peel off the paper. Rub it with your finders until there's no paper left on the board. That should be easy, as usually not much sticks.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:tinygeek(TinyWorkshop)
