3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Make 3D, Light-up, Twisted animal Horns!
Good for Halloween, for Fursuiting, for Festivals and Music gigs, for Lady Gaga wannabes, for Cosplay, or just for fun: some very lightweight, 3D curly or helix-shaped (helical?) horns.  They are hollow, and the lights within them light up the night.  The lights can even be seen during daylight - just not so bright.  These horns are durable, but crowd-friendly.  They have no sharp points, and each one weighs about 100gms (about a quarter of a pound).  I read that the faun's amazing horns in Pan's Labyrinth weighed ten pounds!  No comparison intended.  My homemade horns pale into nothing beside those made by professional costume/prop makers.
These horns have ridges or 'growth rings' like real horns, and the lights shine out from between the ridges.  At night they glow; switch the lights off during daylight, and they even sparkle on a sunny day!  OK, so not everyone's a fan of glitter...
How was I going to make some horns which were all of the above?  While walking through a gardening store I saw some topiary plant supports, and an idea started to form...
Supplies and Tools
  • 2 twisted garden supports – you can get these from chain stores, garden centers etc.  They are hollow tubes made out of soft, thin metal, with a coating of plastic.  They cost about $10 each, but you can use them more than once, if you’re making more than one set of horns.  The thing that makes these great bases for building on – their rigidity – also makes them difficult and unforgiving.  If you bend them in the wrong place, it’s very hard to fix or change.
  • 2 rolls of Soft/Cushioned Plant Tie.  This stuff has a thin wire core and is coated in soft foam, and comes in 10 metre rolled lengths.  It’s a dull green, but once it’s covered or painted, the colour hardly shows through.  I found 2 brands – one cost less than $3 per roll, and the other cost more than $8.  They both look the same, and both work equally well.  1 long horn can use up more than half a roll; if you don’t want to waste what’s left, it can be joined by cutting away about 2½ cm of the soft outer coating at the end of the roll, and pushing the exposed wire carefully into the beginning of a new roll of plant tie.
  • Masking/duct/packing/whatever tape, about 5cm wide.  Cheapest is good.
  • A hacksaw.  This is for cutting the twisted garden supports.
  • Wire cutters.  These are for cutting the soft plant tie.  It cuts really easily.  You can even use scissors; just not your hugely expensive sewing scissors.
  • A roll of cooking/baking paper.  Get 15 metres or longer.
  • 2 sets of lights.  I used strings of 20 battery-operated red or blue ‘rice’ Christmas lights.  They also come in green.  They cost almost nothing if you time it right, and get them just after Christmas.  The only drawback to the rice lights is that once they're inside the horns, they ain't coming out.  I also used some EL or glow wire.  It costs a lot more, and it's not as bright; but you do get a more even glow.  And, unlike the rice lights, the glow wire is easy to remove from the horns.
  • 3 AA-size batteries per string of Christmas lights, or 2 AAA-size batteries per EL/glow wire.
  • Some coloured crepe paper.  It can be matched or toned with the colour of the glitter paint.
  • Foam Glue.  Dries clear.  PVA glue can be used, but not recommended.  Foam glue adheres to the soft foam plant ties better, and it’s stretchy.
  • Glitter paint, water-based, translucent or transparent.  It can be matched or toned with the colour of the crepe paper.
  • A hot glue gun, and 2 or more packets of glue sticks.
  • Some thin string.
  • A very small round or oval fishing sinker.
Step 1Bending and cutting.
Lay your twisted garden supports side by side.  Don’t cut them yet.  Decide
  • which creature’s horns you are going to make,
  • length - you have to be able to get through doorways! and
  • which end of your garden supports will be the part that ‘grows’ out of your head.
For example:
  • Antelope and similar horns grow almost straight up out of the animal’s head, whereas
  • Goat, ram, minotaur, and some types of demon, satyr or faun (e.g. the faun in Pan's Labyrinth) horns usually have a strong curve backwards or sideways, towards the back and shoulders of the creature.
Use a marker to mark, on each garden support, the length you want, allowing a bit extra at each end for handling, and because part of the base is probably going to be hidden if it’s embedded in a headpiece or mask.  Don’t cut them yet, as, unless you have some kind of clamping tool, or some kind of fixed pole to carefully bend them around, they are almost impossible to bend once they have been cut.
  • If you are making an antelope horn, or in other words a horn that grows pretty well straight up into the air, you don’t need to bend the base of your horn much at all.  You can lay your 2 horns side by side, making sure that the curly bits are not parallel with each other.  (Unless you want them that way – I think there might be a type of deer/antelope with curly horns that DO grow parallel to each other).  However:
  • If you are making a certain type of horn (e.g. goat/ram/minotaur/demon/satyr/Pan's Labyrinth faun) that grows out of the front or sides of your head, with an exaggerated curve and then an outward or inward bend at the tip, then each garden support has to be a “mirror image” of the other one – you don’t want a second horn to follow the same lines as the first horn.  Sorry for explaining this in a very confusing way, but you’ll see what I mean when you lay your 2 pieces of cut “horn” side by side, and look at them.  You want the ‘points’ at the tip of BOTH horns to be either facing, or going in opposite directions to each other.  You don’t want them ‘spooning’, or parallel with each other.  This is surprisingly hard to get right.  I couldn’t get my horns symmetrical at all; but I managed to stop them ‘spooning’.  Anyway, I guess real animal horns don’t always look even.
Bend each garden support just above where you used marker pen to mark the base of the horn.  You have to bend them extremely slowly and carefully, because sometimes the garden support gets a kink in it, and it forms an angle instead of a curve.  Bend to the appropriate curve: i.e., almost no bend for an antelope or similar, and an exaggerated bend for a goat or goat-like creature.  Put the 2 garden supports side by side again, and if you’re OK with how they look, then go ahead and cut them with a hacksaw.
20 comments
Sep 11, 2011. 3:56 PMmparker-howerton says:
Okay, so I have been everywhere looking for the twisted garden supports. What store did you get your's at. The only twisted ones I found where metal at Lowes, home depot and Ace did not have any. Any suggestions??
Feb 27, 2011. 1:05 PMcorsairgryl says:
really well done! I think I will be trying a pair for my orc costume
Aug 11, 2011. 12:34 PMmhaag says:
I think the basic idea is brilliant. I'm going to try using a more complex "base" though. Specifically carved clay over a metal armature which I'll then wrap as described in your design.
Aug 14, 2011. 1:14 PMmhaag says:
Do you mean to use the clay to make the finished horn or to make the custom frame? I was orrginnaly going to use the clay only as a mould to take a cast from much like carving clay busts but eventually abandoned the idea.
Instead I've made a metal armature which I will wrap in close cell foam and then wrap as you suggest in baking paper, and then the wrap followed by hot glue. I'm basing my horns off of highly ovoid goat horns that wrap forward.
I'll post a picture of the wire framse soon, apparently this place doesn't support iPad UI so I can't upload it at the moment.
Aug 14, 2011. 6:34 PMmhaag says:
Ok there that's the wire fram for the left horn. I want them to be a little asymmetrical so the right one will be a little longer.
Aug 22, 2011. 8:13 PMmhaag says:
Ok so I did a YouTube video instead of an instruct able but I gave you credit for the base idea. Forgot to put a link in the description but I'll do that in the morning. (new I forgot something) anyway if you want to watch my results here's the link http://me.lt/31EBX enjoy.
Nov 7, 2010. 7:41 PMBadger_Man says:
This fascinates me.....i might integrate these into the halloween costume im building for next year... although i think ill cut out the EL wire, for cost and look reasons... I think ill definitely at least try making one to see how it looks.
Would soft plant tie be available at most places that sell gardening things?
Mar 19, 2010. 12:08 PMthepelton says:
I'm not the author, but that's what I was thinking.  Nice addition to a halloween costume.  You'd be noticed by traffic if they were bright enough.
Mar 19, 2010. 10:50 AMChrysN says:
Nice, are they for a costume?
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
9
Author:Dimensionz
