Step 6Removing the garden support 'core'.
The best way to do it is whatever works best for you. The base of the garden support can be gripped with a pair of pliers while the outer shell is carefully twisted a few times to loosen it. Eventually the garden support will come out. The baking paper will probably follow it out, in a long curly ‘ringlet’. It’s not a big problem if some baking paper gets stuck inside the horn – a few more shouted impolite words, and a bit of tweaking with a long piece of wire or curtain wire should get the rest out. If the paper’s near the tip or the base, and you can see it, use a pair of needle-nose pliers to pull it out.
Add Comment
