Remove these ads by
Signing UpStep 1Step 1: Gather supplies.
A mold, something the right circumference. A soda can could work, or any bottle. I used a bank-thing I had lying around.
Wire, obviously. It should be something you can tell is sturdy enough not to bend when you've actually made the bangle, but flexible enough to shape. You could use any color.
Pliers and a wire cutter. A wire cutter especially.
A soldering iron and solder: Only if the wire you have is solder-able. Mine wasn't, so I just used hot glue.
Beads. Optional.
Nail polish the color of your wire.
A hot glue gun. This is very important.
Music to make bangles to. Zombie Nations happens to be very good bangle-making music. Music is optional, but recommended. Cutting and gluing wires gets tedious.
ehm.. I love the way bangles look.. like a lot of bracelets.. so.. why to cut them? one by one ? can't you just leave it as it was in past steps? just saying(:
...yes, it involves twisting wire... Hear me out, lol.
If necessary, get a slightly smaller gauge of wire - like, only one size smaller than what you make the bangles out of, but again, not so small that it's really fragile. Like I said, if necessary.. You might be lucky and be able to use the same wire.
Anyways, bring back the glue, but probably you want to use super glue or gorilla glue, not white glue or hot glue. You don't want to use a lot, and you'll want to glue as you go..
Use the other wire and wrap it around the closure very tightly. Like coil it up.. And you can do this in such a way where you leave enough on the ends of the coil to tuck them down inside the coil so it's not all poke-y on your wrist.
Basically it would kind of look like this, but obviously metal, not hemp..
www.thejewelryworkshop.com/images/hemp_necklace_closure.jpg
But, like I sed, it's just an idea.. I'm going to try it when I use make my own bangles.. Thanks for an awesome tutorial!
I'm going to go try and twist them one more time. Maybe I'll get lucky and figure out how to do it prettily.
Excellent 'ible. I will have to try this.
