loading
Picture of How to make Bath Bombs
cocoislandsoaps.etsy.com
I'm going to show you how to easily make bath bombs. I love to make them because they're super fun in the bath, and they can be quite beneficial for your skin too. You can customize this recipe with a few tweaks, that I will show you how to do in other instructables. To see more, you can visit my site
Lets start with the materials you need...
Step 1: Materials
Picture of Materials
 This is what you'll need:
- 4 ounces (114g) Baking Soda
- 2 ounces (57g) Citric Acid
- 2 ounces (57g) Corn Starch
- 2 ounces (57g) Epsom Salts
- 2 teaspoons Water
- 1/2 teaspoon Fragrance (I used orange)
- 1 tablespoon Oil ( I used Coconut Oil)
- 1 or 2 drops of food color (1 yellow and 1 red to get orange)
You will also need a mold to give your bath bombs a shape. I used an easter egg, but you can use any mold you want.
Step 2: Method
 1. Start by weighing the dry ingredients. You should always measure by weigh when making bath bombs. I weigh in the following order: baking soda, citric acid, corn starch, then epsom salts. They weigh 10 ounces (284g) combined. You can weigh them one by one or together. As you can see by the picture sequence, I weighed them together.
2. Once you have weighed the dry ingredients, put them in a plastic or crystal bowl and set aside.
3. Now measure your wet ingredients and mix them all in a plastic or glass bowl. They won't mix perfectly, don't worry about that. You should have a little less that 2 tablespoons total of wet ingredients. Maybe you won't need that entire amount. Depends on the weather that day. If it's raining you'll need less moisture. But more on that later.
4. Start adding the wet ingredients to the dry mix one teaspoon at a time. Don't add more than that amount at once because the mix will start reacting. Whisk the mix at the same time you're adding the liquid.
5. When you have added two teaspoons, test your mix by pinching a little bit in your hand. If it stays together and feels damp, your mix is ready. But if falls apart, keep adding liquid, 1/2 teaspoon at a time and testing the mix after each addition. The finished mix should feel like damp sand in your hands. It should not feel wet. If you think you have added too much liquid, add a little corn starch as needed.
6. Now lets get ready to mold. Fill the mold you chose with some of the mix. Add as much as you need so the powder is compressed in the mold, it should be tight. You can leave it in the mold or remove it. I decided to remove it and it kept its form. Some people find that it is almost impossible for it to keep its form after it is removed. So if you've never done this before, leave it in the mold until it's completely dry.
7. Let it dry for 24 hours.
Step 3: Finished Product
Picture of Finished Product
 The bath bombs should feel hard and very dry on your hands when they're ready. The reason you see red bath bombs is because I'm showing you a different batch I made. Your finished product should look somewhat like this ones, depending on the color or shape you used.
Keep them in a dry place for up to 6 months. You can add them to your bath with warm or cool water.
Enjoy!
To see more, you can go to my site.  www.cocoislandsoaps.etsy.com
SweetKissxx16 days ago
Cool
Brianaleah287 months ago
Instead of Citric Acid can I use cream of tartar?
I am not really certain of this answer because I've never used cream of tartar but the citric acid (also called lemon salt) is what makes the baking soda fizz. Kind of like baking soda and vinegar
how many dies this make?
It varies depending on mold sizes and how much you pack into the mold. Really big ones compareable to Lush usually 2 1/2 but unless you have extra help dont make anymore than that at a time because it will get hard to work with and not stay together really well
garsleat5 years ago
I'd love to make these! Where can I find  Citric Acid?
I found citric acid in the canning isle at the grocery store.
cocoislandsoaps (author)  garsleat5 years ago
 I buy Citric Acid in Soap Making specialty shops. I guess you could also find it in health stores. Or try ebay and etsy.
Mscat5912 years ago
Made my 1st batch of bath bombs. They crumbled 5 times but I kept trying and finally got them to staying half mold. They did pop out, but they are showing cracks. What can I change next time image a batch? Also I tried to use the silicone ice trays and they crumbled each time. What can I do to use the trays next time.
try spraying more water on it and/or using less oil to compensate.
Reanahowl2 years ago
thanx for putting this up.
psuder2 years ago
instead of using corn starch, you can use white flour.
kschaus2 years ago
I am going to make these for Christmas presents!
what can u use instead of corn starch
Can we use olive oil?
rolin385 years ago
 I am new to instructables and i like to see some of the older instructables.
OK! Just search up a few of the featured authors! A few personal faves of mine are: Soochmaroo,Kiteman,Belsey, and Jessyratfink. Hope you like it here!
courtesey of your local Maui The Gerbil!
hpolmann3 years ago
Hei, which oil can I use instead of coconut oil? or in what place can I buy it?
ruffyed64 years ago
Which oil can you use instead of Coconut oil?
It is such a great idea. I can't wait to try out. Sure it adds more pleasure to enjoy the bath. =D
Sky3175 years ago
This is great. I may have seen one back awhile ago but then new people come in everyday and they dont have access to the old instructables and the reciepe may vary too. Great job and I will make some today!
Where can I get citric acid?
Any place that sells home brewing supplies will carry it. :)
thanks!
All I can say is THANK YOU!  I have tried literally DOZENS of these recipes...  This is the only one that has ever actually not been too wet, too dry...or falls apart right out of the mold....  High five!
cocoislandsoaps (author)  JosiePosie765 years ago
 I tried lots of recipes too before finding this one and adapting it to my humid weather. I'm so glad it worked for you!!!
Me too...  I had pretty much given up on it....lol  We make soap...bath salts...pumice soaps....  But could never, ever get the bath bombs to actually work.....
pawgles5 years ago
 Just made these today.  Will see in 24 hours how they turned out.  So far so good.  Have been trying to find a recipe that works.  Love bath bombs but having a hard time finding a recipe that works for me.  Either it doesn't fizz or falls apart.  I really like that this recipe goes by weight.  Thanks!
pawgles pawgles5 years ago
 I've tried 12 other recipes for bath bombs.  This one is by far the best recipe I have EVER tried!  Thank you for making it easy, simple and fun!
Thank you!
cocoislandsoaps (author)  pawgles5 years ago
 I'm so glad you had great results!!! Enjoy the bath bombs!!!
notveryreal5 years ago
This has been made already.
http://www.instructables.com/id/How-To-Make-Bath-Bombs/
cocoislandsoaps (author) 5 years ago
 Thank you for your comments! I wanted to share one of the recipes I use. I hope you make these bath bombs and they come out great.
piper12345 years ago
well this is a refresh if someone didn't see any other relalted instructable like this one, besides, it's a sharing of the methods used in their business, the sun shines for all so it might be some couple of similar instructions more over there, what's wrong :P
dkfa5 years ago
Wasn't there Bath bombs from like a few years ago on instructables?
here where I live we don't use of those it'd be interesting to make some ones,
  ; )  many thanks
