How to Make Bismuth Crystals
354,563
239
30
Published
Introduction: How to Make Bismuth Crystals
Ever wanted to make your own bismuth crystals? Well you can by following these steps.
*NOTE: As much fun and pretty as these crystals may be please be aware that this is metal. Melting metals will give off fumes; try to avoid breathing in those fumes for health reasons. For complete details on bismuth and its' properties please read the Material Safety Data Sheet (MSDS) found here: http://www.sciencelab.com/msds.php?msdsId=9927101
Materials Needed:
Metal Bismuth (99.999% pure bismuth is preferred. The cheapest place to acquire some is at Roto's Metals; they sell it by the pound: http://www.rotometals.com/Bismuth-s/4.htm)
2-3 Stainless Steel cups (stainless steel is preferred but aluminum cup will work too. They can be found at any store that sells kitchen accessories. For this example a muffin tin was cut up and used.)
Stove top or Hotplate (propane torch optional) (The hotplate can be found at almost any chemical store online.)
Oven mitts
Tongs
Hammer
Step 1: Melting the Bismuth
Using the hammer break the bismuth into desired sized chunks
Place the stainless steel/aluminum cups into the stove top/hotplate and turn it to medium-high
Wait and watch for the bismuth to begin melting. If not turn up the stove top/hotplate.
Optional: if the stove top/hotplate does not get hot enough to melt the bismuth, a propane torch can be used to carefully melt the bismuth. WARNINGpropane torches are very hot and dangerous. please wear proper hand protection and eye protection before use.
Wearing the oven mitt(s) shake the container and watch for ripples in the liquid bismuth to check and see that it has all melted.
Step 2: Pouring the Bismuth
Set the other stainless steel/aluminum cup into the other stove top/hotplate and turn it on to the same setting as the first one.
Wearing the oven mitts (and tongs if possible), carefully pick up the container of liquid bismuth and quickly pour it into the other cup and set the hot cup aside. (try to pour the bismuth without pouring the gray layer on top; it contains impurities which could inhibit the crystals.)
Turn off the stove top/hotplate that the second cup with the freshly poured liquid bismuth is on. The rate of cooling down affects the size and the structure of the bismuth crystals so the slower it cools down the better.
Step 3: Bismuth Crystal
Wearing oven mitts, gently shake the container again to check and see if the bismuth is becoming solid. (This should appear to look like very little rippling when the container is shaken.)
Quickly pour the liquid bismuth into the first container that was used. There should be bismuth crystals in the second container.
The bismuth crystals can be snapped out of the container after the bismuth is completely solid, or they whole shape can be saved. Crystals should form in the other container as well.
If the crystals are not to your liking, the bismuth can be remelted and the process can be repeated until the desired crystals are made.
    • Woodworking Contest
      Woodworking Contest
    • Make it Move Contest
    • Oil Contest
      Oil Contest
    30 Comments
    first time here!!!
    I have a decent amount of slag-like bismuth from making a few pours today. I was wondering if there's a flux or something I should add before remelting the metal, to reduce this useless layer.
    Any thoughts?
    This is cool.
    Have you ever seen a solid Helium before?
    No one has ever seen solid helium before. It's practically impossible to get helium cold enough to solidify it.
    True, it is hard to make solid Helium. Did you ever heard the term 'super-solid'- it is a condition that every atom in a metrial can't even move, only happend in absolute zero.
    This is how solid Helium looks like: http://www.spacedaily.com/reports/Shaking_down_frozen_helium_In_a_supersolid_state_it_has_liquid_like_characteristics_999.html
    I bought my Bismuth from here on ebay and my crystals looked great! Definitely will do this again!
    http://www.ebay.com/itm/100-grams-Bismuth-Metal-99-99-Pure-Element-Crystals-Ingot-Chunk-USA-/251976590733?pt=LH_DefaultDomain_0&hash=item3aaaf9a58d
    Looks amazing!
    What I was wondering now though is can you get any stainless steel shaped mold/container and do this with them? I thought it would be cool for a project to get like a stainless steel Pi symbol mold and make a crystal Pi.
    Yes I have done the process with just a cup cake tin but it would be cool if other shapes would work.
    We found that German battleship was makin' such a fuss
    We had to sink the bismuth 'cause the world depends on us
    Cool! I had to do a project on Bismuth for school and this really helped. Thanks!
    Neat! can't wait to try it, if my mom lets me. I'll post if it has any dangers or value. 8^D
    Turns out it is only worth a few dollars, but still interesting. Just don't try to sell it at a high price.
    thanks.we also process bismuth lump into needle shape and granule shape.If anyone interest,we are available anytime
    richard castle
    cabinnature@gmail.com
    skype: castle8009
    What services do these pose?
    Where did u get the idea? please post as soon as you can!
    Sorry but how safe is it to melt bismuth? From what I've heard, the fumes given off by melting bismuth can be extremely dangerous. Is this true?, because this is something I really want to do but I'm anxious about the danger to my lungs.
    I used your method and this thin layer of yellow dust formed on the inside of the pan where it was in contact with the bismuth. It could be a contaminant but I don't think that it would coat the inside since its 99.9% pure or it could be a nonstick layer that separates with high heat. It happens every time I melt the bismuth. Do you have any idea what it is?
    Well, even though it is not a contaminant, it is considered one. The thin yellow layer is bismuth but it is a chemical reaction that happens when hot liquid bismuth comes into contact with oxygen in the air. This can happen sometimes if the process takes too long. In that case just use something like a fork to gently scrape off the yellow layer and wipe it on a paper towel.
    do i gotta go to Bismark to get Bismuth?
