I had a lot of fun making these, and I know she's going to love them.
UPDATE: I gave them to her tonight (12/6/07) and she really did love them, they're burning now.
Remove these ads by
Signing UpStep 1: Caution
*Wax is very hard to clean up from counters. In order to help with cleanup, use as few tools as possible, and cover your work space in newspaper. I wish I had done that.
*Wax is flammable, for this reason, it's very important that you don't use any setting higher than medium on your stove, and use a thermometer if possible.
Wax's flash point is 300 degrees F, don't let it's temperature exceed 250 degrees.
Visit Our Store »
Go Pro Today »
Some thoughts:
- Block of wax was $20 for me. I didn't want to shell out that kind of money in case this was one-time thing, so I bought several wax cubes for $6. I used only ten cubes when making my candle; they melted fine.
- I also didn't have a double boiler, so I used a frying pan. Not sure of the advantages/disadvantages here but it seemed to work ok.
- I used a small container for my candle. It looks much prettier I think.
- You. are. not. kidding. about the tough clean-up. I probably spent more time cleaning wax off my pan than I did making the darn candle. One little tidbit of advice I can offer is that the wax seemed to build-up in some areas, and instead of rubbing harshly I tried to scrape it off from underneath. That seemed to be more efficient.
Thanks for posting this! :)
I would like to use you and your message as an example to many parts of the world of what a paranoid unintelligent american is. Not only will I explain it on this site but will use this comment on nearly 30 other sites where I give an explanation of the unintelligent, small knowledge based anglo saxon. I too am an anglo saxon American, but for some reason I am able to see our enormous shortcomings. Don't worry bob you're not alone, there are many people like you that I use as examples.
If you follow the instructions there is no reason why you would have hot water, wax and pots flying all over the place and (scare tactic) all over your face, down your throat and through your bones. The people who would not follow the instructions (anglo saxon male americans) yes would probably have a mess on their hands, but even they are smart enough to jump out of the way if two pots explode. However these people do not have the ability (such as yourself) to see the benefits of going through this process to make candles. It is something that you can do for fun with others to create a useful tool. So bob please don't go buy candles, but spend the next 36 hours sitting down in a chair with a candle lit and think about why this is a good thing. If you still cant figure it out, there are plenty of good psychologists out there who became psychologists to help people like you.
Lay the wick on something flat, like a flat surface. It dries very quickly and if left undisturbed will not curve on its own.
Maybe just buy the candles.
2. (S)he decided to make the candles so that (s)he wouldn't have to buy them for a fortune. Nice job reading.
Using a potholder or two, pour the wax into your clean votives or whatever you're using as a container. Use whatever method you prefer for setting the wick. I use the pre-tabbed/pre-crimped ones, for ease. I buy them for $5.95/100pcs, and they last me a LONG, LONG time.
I am not a true "candle maker", per se, but I hate wasting all those little ends of candles ... once melted down, I can usually get 3 or 4 more votives ... and that's about $12+ , if you buy the Glade ones.
I use this jar-melt method, and I have NEVER had a spill, or any mess whatsoever. Whatever sticks inside the jar ... well, it'll be melted down into the next batch, the next time I make candles!
Oh! ... I also bought a 73¢ plastic, 3ml pipette (a dropper) at Sally Beauty Supply, and use it for my scents. I keep that JUST for measuring the scented oils, so no muss/no fuss w/ the scented oils, either.
suggenstions?
I also poke a small hole through the bottom of the paper cups, and thread the wick through that (seal it with a bit of wax from another candle).
Example here:
https://lh6.googleusercontent.com/-wXJQ74Oav8o/RpwqRy1Gl5I/AAAAAAAAAEc/UhMJH_aUNe8/s640/090720073413.jpg
You said that if you were using a glass as a mould then you should grease it to get it out.
Couldn't you just leave it in there so the glass could be like a candle holder?
http://howtomakescentedpillarfloatingbeeswaxcandles.com/
I get it at Michael's. Yaley Enterprises is the manufacturer, marketer, etc.
Thanks.
There's nothing dangerous about a large block of wax over boiling water. It would take hours, if ever, for the wax to soften to the point of breaking and falling in.
Use candle colorant instead of crayons better results and costs less. No sediment on the bottom of the pot.
I have found that "most" oil based sents(sp!) work in candles. Try Frankincense or Muir... Or both OH so nice. On the oils that come out (evaporate) of the candles to fast I dip the candles in hot wax after unmolding and cooling for a day.
Use tapered molds and after cooling the candles usually just fall out.
OR pop the tools in the large pot of the double boiler and boil a bit. Let cool skim hardened wax off the top and retrieve tools. You will only have a bit of wax at the water line of the pot to clean up. My bamboo scraper and a bit of hot soap and water takes care of that.
I envy the skill you must possess
