3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
How to make Candles!
Step 6Pour the Wax
Pour the Wax
Use the double boiler to pour wax into each mold, then stick the candles into your fridge. This will speed up the cooling process. Once they are starting to firm up, and the top of the candle looks firm, use a tooth pick to poke into the center of the candle. You'll notice that the inside of the candle is still melted. Position the wick straight up, and so that it touches the bottom. Melt a small piece of wax over the wick's hole to seal it. Leave the candle in the fridge until fully hardened. When they are hardened again, either peel off the mold, or slip out the candle (depending on your mold)
« Previous Step   View All StepsNext Step »
4 comments
Feb 16, 2012. 1:27 PMalwayssummer says:
Do you think a straw would work for a center hole for the wick? if you oil it before inserting and if it actually comes out you would wind up with a nice 1/4" hole in your candle.
Dec 4, 2010. 10:09 AMucanBanerd says:
They make a pin for candle making, most times you pour wax twice, because the center where the wick is, sinks as it cools and you get a bit of a hole. The pins go in the bottom of the mold and makes it so after the candle hardens there is a prefectly straight hole through the candle, thread your wick through the hole, then when you repour (make your wax 20 degrees hotter so you don't get a line) it fills the gaps and your wix and your hole from cooling are fixed. I'm going to try to improvise one for pillar candles using a bamboo skewer.
Dec 12, 2010. 2:20 PMBad Maxx says:
THANK YOU! I've been curious why all of my candles sink in the middle making a big ugly divot! Also makes the candles burn wrong! Now I'm re-inspired to make candles again!
Thanks.
Dec 13, 2010. 8:04 AMucanBanerd says:
There are some waxes that don'e require a re-pour, but most do, and the second time, your wax needs to be ten to twenty degrees hotter than on the firts melt, so you don't get a line. I've already screwed this up once, lol, but if it's just for home, no one cares. I make the batch a few ounces bigger than i need, then re-melt whats left in the pot for the re-pour after your wax cools the first time. I also noticed that you will get a much worse hole if you try and speed things up by putting them in the frige!
Dec 13, 2010. 3:49 PMBad Maxx says:
I agree with the fridge making it worse! My first candles had a rather shallow sink-hole to them, then thinking maybe cooling them faster would prevent this, I put my next batch in the fridge. Way worse! Can't wait to try your method.
Dec 7, 2007. 6:22 PMBrennn10 says:
Nice Leatherman in the background!
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
151
Author:Weissensteinburg
I enjoy photography, horticulture and carpentry, and am almost always doing something relating to of those things. Feel free to send me a PM for whatever reason.
