How to Make Cheap Speakers
5,679
18
4
Published
Introduction: How to Make Cheap Speakers
Step 1: What You'll Need
A broken headphone (the cheap ones), soldering iron, pliers, knife, screwdriver, tape, wide scotch tape, thin scotch tape, glue (a strong one and a normal one - as you can see, I do not have the normal one...) and a ruler (that I also don't have, so I used what I do have).
Step 2:
Take it apart carefully. Look for broken things or a loose wire. Here everything is ok, but usually this is where the fault lies.
As the speakers didn't had any problems, I didn't have to do nothing.
Step 3:
Start breaking with the pliers untill there's just the slot. (This is what will protect the phones).
Before you break it, remove the foam carefully ( Yeah, i forgot to take a pic for that...).
Then, you measure the slot and adapt the image to it's size.
Step 4:
The volume control had a loose wire, so i fixed. (Its really easy. There are markers to every wire, the hard part was soldering without really knowing how).
As it was hard to keep the wire in the right place, I made a tool with some hard wire.
Step 5:
Now, you'll glue the foam onto the slot and on the foam. Use the strong one. Let it dry for about 10 minutes. It can take more or less time to dry, depending on how much you used.
Step 6:
Use some internet image as reference and make your pattern. You can use this one or any of your choice, as long as you like it.
Cut the shapes and make a small cut in the middle of the black circle with the knife blade. Then remove the black circle leaving a small black outline.
With a ruler (a normal one, that you have and I do not...) fold the cubes. Do it on both sides.
Step 7:
When the glue is completely dry paste the foam and try to center both. Cut the excess foam leaving a small border. Put some glue in the border.
Step 8:
Put  a little glue in the holes borders and tabs. When it dry, place the slots in the holes.
Now, some glue in the tabs. Please use the normal glue, the une made for paper. As you can see, I really don't have it.
Start to assemble the pieces like shown in the picture.
Step 9:
Put the phones in the slots and cut a piece of the large scotch tape and place it on top of the phone (usually the phones stuck in place just fine, but it's good to assure).
Step 10:
Glue another part of the cube and cut a small piece small form the corner so the wire can go out. Cut the scotch tape to keep the wire in place.
Step 11:
Finish the box carefully.
I ended up keneading the box because of the glue I used. Use a hard wire in the corner to make the cube straight.
Step 12:
    • Casting Contest
      Casting Contest
    • Clocks Contest
      Clocks Contest
    • Planter Challenge
      Planter Challenge
    4 Comments
    I like, though I think I'd glue my design to some card stock or something of the sort.
    Looks very nice, with good descriptions and great photos, but a few suggestions:
    • Add a link to the source of the image you printed and cut out. If you made it yourself, upload it and insert it into a step. Everything is based on an image that we don't have.
    • Combine some steps. You could easily shrink this  from 46 steps to less than 10 and make it that much more readable. Put all the descriptions and photos of cutting out pieces in one step, everything about pulling apart and fixing the headphones in another step, etc.
    • In the editor there is an "embed video" icon that will let you embed the video from Step 45 directly into the Instructable.
    And since this is your first Instructable, this is where I say, Welcome!
    46 steps with not even a sentence per step, must be a record.
