3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
How to make Caffe Mocha
  • last photo ←
Previously known as:
How to make Chocolate Frappuccino Mocha Latte
For those of you who are poor like me, or simply love doing things DIY even early in the morning, this is for you.
The name is complicated, I swear the ingredients are not. This took me 15 minutes the first time, and It'll take you less once you have the syrup on the ready. This is made from normal coffee, and not expresso. (If you want it to taste more expresso-like, just add a teaspoon more of coffee when you brew it.)
I like mine hot, but you can cool it by sticking it in the fridge or adding ice. Just don't add ice first (in the cup) then add the hot coffee, or else you could break the cup.
You will notice that most of the drink is actually just milk, and only 1/4 to 1/5 of the actual mix is coffee.
For one cup you will need:
Syrup (this makes a small cup of syrup, so you can use it maybe 10-15 times again, same recipe)
1/4 cup of cocoa powder (NOT GROUND CHOCOLATE)
1/2 cup sugar (I used a little less, maybe 3/8)
1 dash salt
1/2 cup water
1 teaspoon vanilla extract (make your own!)
Coffee
2 teaspoons your choice of ground coffee (I chose Trader Joes Bay Blend Arabica Beans)
1/4 cup of hot water
3/4 cup of hot milk (you can steam this if you have the tools)
Sidenote: Don't forget to rate and vote! Thanks!
Step 1Make the Syrup
Make the Syrup
Now for those who like this drink a lot, you can multiply the recipe however you like.
You can use that weird Hershey's Syrup stuff, but honestly, there's too much other stuff in there besides the chocolate, and its a bit too sweet for me.
Unfortunately, I haven't any pictures of this step, but it shouldn't be too hard.
Mix the cocoa and sugar, and put them in a sauce pan.
Heat on Medium-High.
Leave it in there for a minute or two (any more can actually burn the chocolate leaving a strange smell/taste, but if you want, you can heat the sugar first, making it more caramel-like. Just don't put the chocolate in first then), mixing the dry cocoa and sugar, so the sugar can heat up, and perhaps burn a little for a more caramel-like taste.
Add the water slowly, thirds at a time, mixing well in between.
Then add a dash of salt (brings out the flavor, but just a tiny bit!)
Once mixed completely, the mix will probably be already boiling, so lower the heat to a Medium, let it boil for about 5-8 minutes mixing constantly.
Boil until mixture thickens, you will notice that if you move your spoon (or whatever you're mixing with) fast through the mixture, you can see the bottom of the pot for a quick second.
Don't worry if it looks feels or looks too viscous, it will harden once you turn off the heat.
Turn the Heat off, let it cool for a few minutes.
I boiled a small jar (to kill bacteria), then poured the syrup in there.
59 comments
1-40 of 59next »
Dec 15, 2010. 12:53 PMMakerBorn says:
Great 'structable! I got to go to Paris (free!) in October, and I've been craving something like this (that I can actually afford) ever since. Thanks!
May 20, 2010. 12:15 PMmojobo1 says:
Great 'ible, my only problem was the frothing.. I have a Mr. Coffee (really cheap) and I guess the frother just doesn't have enough pressure to properly froth the milk. It barely froths it then as soon as you take the wand out the bubbles disappear. :(
Still good though. I loved the syrup!
Oct 17, 2010. 7:05 AMGreyHat 64 says:
I think I have the same espresso maker! I got it to work once but it never worked again
Jun 24, 2010. 6:57 PMshostakovich says:
oooooh.. good... thanks ;-)
Feb 3, 2010. 7:25 PMjjinyancey says:
Does it matter what kind of milk you use...whole milk, 2 %, whipping cream...?
May 20, 2010. 8:22 PMmojobo1 says:
The lower the fat the easier it is to froth, skim being the easiest, but the more fat the better it tastes. Skim is good if you just want to learn how to do it, then move on to 2%
Nov 8, 2009. 10:03 AMREDandroid says:
 I like the fact you show how to make the syrup. I have been looking for ways to make these drinks at home without the espresso machine because i'm dirt poor, and I'm addicted to Mochas. I bought a Billetti Italian espresso maker ($35) that works good for making espresso on the stove. The French press dosen't extract the flavor as good as i'd like, but i could be doing something wrong (there seems to be a million techniques to use this simple device :). This instructable was good info! THANKS!
Jun 3, 2009. 4:04 PMRotten194 says:
I love this. Fave, 5*
Dec 7, 2008. 4:44 PMdeirdre625 says:
So I made this and the chocolate seized when I added the water! Annoying! The bit that I salvaged was tasty, but how do I avoid it seizing in the future?
Dec 8, 2008. 5:22 AMdeirdre625 says:
Seize means it went hard and grainy when I started adding the water - it happens very often when adding water to melting chocolate.
http://www.thekitchn.com/thekitchn/food-science-why-chocolate-seizes-048510
I melted the sugar and added the cocoa as soon as it started to get liquidy. Then after it was thoroughy dissolved and mixed and looking beautiful, I sprinkled in some of the water and it went immediately hard. I used organic sugar (raw) and ghiradelli cocoa.
Apr 29, 2009. 10:09 AMeetzel says:
Did you use the Ghirardelli ground chocolate or cocoa? If you accidentally used the ground chocolate, it would seize up the moment you add water. Chocolate and water do not go together - "When moisture/liquid gets in chocolate, it's like oil & water - they don't mix. A drop or two of liquid can cause chocolate to seize (form hard lumps) and become unworkable..." (http://www.chocoley.com/chocolate101.htm) That might have been your problem.
Apr 23, 2009. 7:00 PMMrUbuntu says:
One of my favorite instructables ever! I am also poor so thanks a lot! 5 Stars!
Apr 6, 2009. 6:06 AMmadmanmoe64 says:
too poor for an espresso machine!!??, You can get basic ones for £20. mine makes espresso and steams milk (which is how ur supposed to get the froth, those hand whisks r useless)
Mar 27, 2009. 3:05 PMartificially_flavoured says:
Great instructable! I found that if you add more coffee and a tenny bit of honey and Sugar in the Raw, it gets rid of the slightly bitter aftertaste. (maybe that's just because I use bad coffee) Cinnamon tastes good with it too.
Feb 18, 2009. 2:36 PMhg341 says:
HOLY HELL I WANT YOU F!@#ING BIG CUPi liked it but i do this with half and half a little milk some suger that weird Hershey's Syrup stuff and mostly coffee
Mar 18, 2009. 5:09 AMhg341 says:
shift 6 its the little carrot i would show you but it wont let me
Mar 19, 2009. 5:09 AMhg341 says:
yea
Feb 28, 2009. 12:21 PMTzGirl says:
Thanks for a nice, detailed description - sounds delicious & I hope to try it myself sometime soon !
Mar 13, 2009. 6:28 PMDarkKnightJared says:
Oh hell yes, I'm doing this. No more paying four bucks for decent coffee! :D
Feb 19, 2009. 1:59 PMD.A.N says:
how big is a cup
Feb 19, 2009. 5:51 PMhedgiehog says:
mm looks good, so a quater cup coffe is needed, which is relative to how much syrup, and how much milk?
Feb 19, 2009. 1:23 PMPyromaniacDaniel says:
Chocolate Frappucino mocha latte - ok so mocha means chocolate in the coffee. Latte is short for cafe latte and means that there is milk in the coffee. However "Frappuccino is a registered trademark of Starbucks and is the name of a blended ice beverage and of a bottled coffee beverage."(excerpt from Wikipedia) neither of which this is? Other then that Great Instructable!! will definately give it a try!!
Feb 17, 2009. 9:51 PMYerboogieman says:
So, pretty much hot milk hot coffee hot syrup with optional ice? Sweet. i'll have to try it.
Feb 17, 2009. 9:02 AMjesseh says:
that was pretty much as good as stuarbucks. great job
Dec 1, 2008. 6:07 AMmrtentaclenun says:
The name of this is so redundant.... chocolate = mocha. same thing. frappuccino= drink blended with ice.... latte is espresso or coffee and milk... so this is just basically a mocha latte
Feb 17, 2009. 6:55 AMellsswhere says:
Just remove Frappuccino... Chocolate Mocha Latte is still correct. Frappuccino is simply misleading.
Dec 2, 2008. 8:41 PMYerboogieman says:
now for a soy iced caramel Macchiato
Feb 8, 2009. 5:22 AMmrtentaclenun says:
Put some vanilla and soy into a cup, top with ice, put shots of espresso on top of the ice and caramel sauce!
1-40 of 59next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
12
Author:flio191(my personal blog/portfolio)
I'm from Chicago, but currently at University in Champaign-Urbana, studying fine and applied arts. I hope to focus on information design and computer science within graphic and industrial design. I ...
more »
