How to make Clay Lanterns by ChrysN
Contest WinnerFeatured
I am not sure if that is the best name to describe this, but it is basically a cup made from air-dry clay in which you can place a tealight or small candle.  I made an impression on the sides of the cup and then poked small holes in the clay allowing the light to pass through.  I saw something similar done with a tin can and really liked how it looked.  The candle light through the holes is subtle and the design impressed onto the clay looks nice even in daylight.
Step 1: What you will need:
  • clay -any kind* or colour (I used La Doll Premier Lightweight Stone Clay)
  • clay rolling and cutting tools and a mat to work on
  • stamp, stencils or anything else you want to make an impression (Sculptey has texture making sheets and wheels)
  • cling wrap (to protect mat)
  • bottle the size and shape you want for your lantern
  • sandpaper
  • needle
*check that the clay is not flammable (Crayola air-dry clay is and it warns against using it for making candle holders)
fonzuzu says: Aug 24, 2011. 7:29 AM
Hers'e the one I made, sorry it took a while to post.I know it's abit messy but I made these lines on it with the pencil, I 'm sure if you do it properly it will be really cute.
ChrysN (author) says: Aug 24, 2011. 4:04 PM
That looks great! Thanks for sharing.
nisha_m says: Oct 31, 2012. 2:19 AM
how long does the clay take to dry?
ChrysN (author) says: Oct 31, 2012. 10:44 AM
The clay I used air dries over night.
Master Beorn says: Dec 2, 2011. 3:32 PM
You might try dimpling the bottom a touch and installing a small electric light as well. This also works VERY well with porcelain.
tjesse says: Sep 27, 2011. 2:01 PM
A pounce wheel could speed things up. Check out my watermelon frog instructable for an example. This project would make a great mother's day gift!
ChrysN (author) says: Sep 27, 2011. 4:00 PM
Thanks for the tip, that would be really helpful!
mstyle183 says: Sep 26, 2011. 6:48 AM
Good luck!! it looks great
ChrysN (author) says: Sep 26, 2011. 3:43 PM
Thanks!
LifeWarrior says: Aug 21, 2011. 8:28 AM
Very sharp use of stenciling, I've never been good at clay sculpting, but I'm always fascinated by the artistry of it, it's cool to see an actual technique in action. Great 'ible, Thanks
ChrysN (author) says: Aug 21, 2011. 11:09 AM
Thank you!
ZoDo says: Aug 19, 2011. 6:32 AM
As always, I am ipressed by your work. You have my vote.
ChrysN (author) says: Aug 19, 2011. 4:14 PM
Thank you!
kasengut says: Aug 17, 2011. 1:54 AM
You can make the base a little bigger with a rim, into which the cylinder can fit, - and don't connect the base and the cylinder. That way you can place the tealight on the base and cover with the cylinder, - you don't have to drop the light in !
Nice work !
ChrysN (author) says: Aug 17, 2011. 4:48 PM
Great idea, it is a bit awkward putting the candle in, thanks!
fonzuzu says: Aug 13, 2011. 5:46 AM
this is soo cute i made it but i took a sided pencil and rolled it over the clays to make these even stripes that look really cute and i drew a tree . thax sooo much for posting post more thing like this from clay plz
ChrysN (author) says: Aug 13, 2011. 11:31 AM
Cool, I'd love to see the one you made.
friendorphobia says: Aug 11, 2011. 8:30 PM
You did a great job sanding the rough spots. It's hard to do - I tend to push to hard in one area, sanding it too much and making it uneven. An easy way to sand the top to make it even would be to turn it upside down onto the sandpaper and sand it with a circular motion, trying to keep it perpendicular. Love this project!
ChrysN (author) says: Aug 12, 2011. 4:34 PM
Cool, thanks for the tip!
sunshiine says: Aug 9, 2011. 2:50 AM
Thanks for sharing! AND congrats on beaing a featured author!
ChrysN (author) says: Aug 9, 2011. 3:37 PM
Thank you!
sunshiine says: Aug 9, 2011. 3:57 PM
You are welcome!
penelope nicholls says: Aug 7, 2011. 2:33 PM
Love this creative idea. Do you oil the bottle first, so the clay won't stick to it ?
ChrysN (author) says: Aug 7, 2011. 3:11 PM
I put some cling wrap around the bottle and only wrapped the clay loosely around it but oil would probably work better.
xavec says: Aug 7, 2011. 10:43 AM
I love this so much - will definitely have to make one at some point!
splazem says: Aug 5, 2011. 8:26 AM
Wow, amazing (yet again)! Keep up the good work!
porcupinemamma says: Aug 4, 2011. 8:06 PM
Beautiful! A child could do this, and a battery operated tea light could be substituted for a real candle
ChrysN (author) says: Aug 4, 2011. 9:31 PM
Yes, it would be a fun activity to do with children. Thanks!
CatTrampoline says: Aug 4, 2011. 12:32 PM
I really like this. Pretty and useful. It would also make an attractive pencil holder if you didn't need a lantern.
Infinite_Ideas says: Aug 4, 2011. 2:53 AM
This is really cute, I think little mini ones of these might look really good as part of a natural themed wedding. One or two on each table.
jessyratfink says: Aug 3, 2011. 10:18 PM
Such a good idea! I think I might make one of these to hold a tiny metal bowl for an additional oil burner. :)
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
