loading
Step 5: Gel Recipe
1. Mix the water and salt in the glass bottle.
2. Slowly pour in the flour. It will become gelatinous. Mix it until it the consistency is even throughout.
3. Add a drop of bleach to sterilize the gel.
Note: Just use regular white flour, not fancy whole grain flour like we used in this demo (it was all we had).
Great idea
HI amigo me podrias dar tu correo, me gusto el proyecto y me gustaria hacerte varias preguntas, soy estudiante universitario.
<p>Any substitution for flour in the conductive gel? I assume it is wheat flour because it is simply stated as flour. I am allergic to both ingestion and skin contact of gluten. Any work-arounds that would be just as conductive?</p>
here is a link to gf playdough<br>http://onecreativemommy.com/gluten-free-play-dough-recipe-review-and-tips/?m
You could try a gluten-free flour like rice, almond, taro or the others. Good luck!
<p>Xanthan Gum would be a better option (cheap to buy online). Just a tiny amount would be enough to create a gel and would be conductive with a little salt.</p>
<p>Awesome</p>
God Bless you , man! <br>It was Amazing. Good Luck
<p>Could the conductive gel be created by adding salt to K-Y Jelly?</p>
<p>K-Y jelly drys out too fast </p>
<p>This is great!</p><p>Some of you may also find this little update on how you can repair broken shielding on ECG cables useful:</p><p><a href="http://davidkvcs.com/2015/01/11/how-to-repair-broken-shielding-on-ecg-cables/" rel="nofollow">http://davidkvcs.com/2015/01/11/how-to-repair-brok...</a></p>
<p>&quot;snap buttons, size 3&quot;, what would that mean :s</p>
This is great, and for a good cause as well! Would this also work for EMG (muscle) sensing?
I have never had reason to comment on this site, although I enjoy many of the instructables. This one tops them all. This could truly be life saving. Thank you, from the rest of the world.
Thank you, so good of you to say. We'll pass your kind words on to our friends at Engineering World Health, too, to spread the love.
if u used thermal electric generators. instead of battery's they, the instrument could be powered by the user instead of a external power source, as well. if u go to http://tegpower.com/pro4.htm if the full link doesnt or refuses tto work look at the base link then products page <br>
Could you use cotton for the pads?
Step 3, &quot;1. Cut an &ldquo;X&rdquo; in the center of the lining to make a hole, no larger than <strong>1cm</strong> on each line.&quot; Typo: this should read &quot;...no longer than <strong>1mm</strong> on each line.&quot; I'm sure everyone else read it correctly, though.
When I was learning to do ECGs as a medical student, a little over 20 years ago in Melbourne Australia, our ECG machines used washable suction cups as electrodes. Actually, I see they are still made - http://www.diytrade.com/china/4/products/7681402/Multifunction_Suction_ECG_electrodes.html<br>I bet a lot of these have been thrown out, when they might have gone with the ecg machines to better homes.<br><br>If you cook the flour water mix, you'll need a lot less flour to get the same texture.<br><br>Great work!<br><br>Jennifer
creative idea now the issue where to get some pads is well ended!!!
Hello - This is a very nice solution and well documented. I had not thought about medical equipment from this perspective. <br><br>It sound like donated equipment needs to be &quot;de-Americanized&quot; for use without disposables. <br><br>I could also see where there maybe safety and proprietary features that are useful in the developed would, but would present a significant barrier to use elsewhere. <br><br>Is there ever an opportunity to modify the equipment before it is shipped off?<br><br>I also wanted to add that if you have disposable diapers, you can make electrode gel from the water absorbing crystals by removing them from the diaper and adding salt and water. One diaper will make a cup or so of gel. It is like ultrasound gel. <br><br>A disposable diaper with salt and water should work as an ES ground pad as well.<br><br>Of course, that is if you have disposable diapers.<br><br>I like the 'play-dough' solution better.<br><br><br>
Do you use new diapers, or can you cheat and use one that already has salt and water added to it? :)
Yuck...
Huh, hadn't thought of diaper crystals. Interesting, thanks!
This is absolutely brilliant, and a much needed alternative to massive use of disposable supplies. Thank you for sharing this excellent idea.<br> <br> Do you think the pads and conductive gel will work well for use with a wearable TENS unit for pain management? I could try making the pads bigger like mine, which are some sort of black conductive rubbery stuff, about 40 mm across. But the best gel I've been able to buy is usually only good for a few hours before it dries out and needs to be re-applied to the pads, and new skin tape.<br> <br> A long time ago I tried some self-stick conductive pads coated with a thick conductive gel made with (I think) agar. They were marketed for people with sensitive skin. They worked well, since I have trouble with the glue on skin tapes, and they lasted for several days of application, removal, and re-application, but they were disposable and quite expensive. Any ideas on how to make your pads &amp; gel self-stick? It could radically reduce the need for all the tape needed to keep the pads in place, especially if the gel doesn't dry out too fast without needing tape around the pads.<br> <br> I'm delighted to see this excellent and important contribution on Instructables! Thank you!
Haven't heard of DIY self-stick pads, yet, but we'd be interested to see it if someone has an idea. Thanks!
Nice method.&nbsp;A few hints on ECG pad usage though since I can imagine a few people here using these in their own experiments.<br> <br> After cleaning be sure to dry the skin.&nbsp;Ironic as it might be; Don't use wipes with alcohol at all since it may cause excessive drying of the skin. And go over the skin once or twice with a fine abrasive, just be sure it's clean and doesn't cause any skin damage. Fine sandpaper generally does well. All of the above is essentially what makes those &quot;ECG Prep Pads&quot; so special (and expensive).&nbsp;Especially the latter step might seem weird, but it reduces the skin contact resistance&nbsp;significantly.<br> <br> Also be sure to not leave the wire hanging if the person the pad is applied to is able to move. Movement causes a lot of noise. Attach the wire to the skin with some extra tape.
Great, thanks. These tips are a nice complement to the Instructable. We'll pass them on to our friends at EWH.
Cornstarch might work instead of flour. It's a very interesting Instructable. Thank-you for teaching me something.
I have used a thin layer of (liquid) honey very successfully, and find that it lasts for quite a while.
Is Borax 'slime' conductive? That might make a better gel than flour, although I can see how flour would be easier to get ahold of in the developing world.
Sometimes the soft drinks have a look under the cap contest where you can peel away the liner by hand. That'd make collecting the liners much easier.<br><br>There is also an abundance of scratched prepaid phone cards that are discarded in Africa everyday. Do you think they would make a suitable substrate?
Good tips. We'll suggest the phone card idea to EWH to see if they can use it. Those cards are all over the place, right?
Have you considered using rolled up condoms in lieu of the plastic liner in the bottle caps? They are significantly larger but they may serve equally well and avoid the need to boil the caps which could be a bit of an undertaking in certain parts of the world. Just a thought.<br> <br> Great post!&nbsp;
Interesting idea, thanks. We'll pass it on to the researchers at EWH.
Great work!! I can't wait to try this out.
you could save the world with this you need to tell someone!
Thanks, we're trying! We have this project as a solution in our Solutions Library: https://www.engineeringforchange.org/solution/library/view/detail/Health/S00058<br><br>And Engineering World Health is also trying to spread the word through training courses it offers in developing countries.
now... can these be used to detec nerves, and pulses and stuff like that?
They're part of ECG machines, which can detect electrical potential on the skin to measure heart rates and, indirectly, blood flow to the heart. New applications might require new machines that they link to. Thanks for your interest!
THANK YOU
About This Instructable
221,742views
245favorites
License:
Bio: E4C’s mission is to improve the lives of underserved communities by better preparing the global development workforce, optimizing the solutions development cycle, and ensuring ... More »
More by Engineering for Change:Make a better penetrating oil How to make a tool set How to make a corn sheller
Add instructable to:
