Remove these ads by
Signing UpStep 1The Parts
Black Acrylic plastic - acquired (free scraps) from Regal Plastics in Houston
Glue/Adhesive (IPS WELD-ON 3) - acquired from Regal Plastics in Houston
Plasticator squeeze bottle applicator - acquired from Regal Plastics in Houston.
Printed image - from the Internets or your artistic ability
drill
exacto knife
EL wire soldering materials - see: http://neonstring.com/index.php?tasket=solder
But for this Instructable, I used the tiny 1.2mm wire, aka "angel hair" wire. It seems to be much more forgiving, because I really pinched the wire to get those points as sharp-looking as I could, and there were no failures, no problems.
I knew getting sharp points with 2.5mm wire would be very iffy. On the Jack-O-Lantern, I used 2.3mm orange for the teeth, and I pinched them really hard to make the teeth look pointy... and the wire failed completely - I had to pull the EL wire off the mirror, wiggle it around until it worked, and re-glue it. So apparently, if you need to make some sharp points, 1.2mm wire is the way to go... although this Instructable here:
http://www.instructables.com/id/Removable-EL-wire-art-panels/
shows a brilliant way to get sharp looking points without actually stressing out the EL wire with any sharp bends.
http://neonstring.com/index.php?tasket=videos
And look at the third video (the Jack-o-lantern one), you will see what I mean. When it shows it from behind, you can definitely see the edges illuminated.
As for the wiring, there are already Instructables on soldering EL wire, and I have very detailed, illustrated, step-by-step instructions on my website, here:
Many EL wire drivers are powered by 12 volts. There are EL wire drivers that run off of two watch batteries, some that use a AAA battery, some that use an AA battery, a 9 volt battery, 12 volts (cigarette lighter plug or 8-AA battery pack), and some drivers you can plug into your household electrical outlets. It just depends on
1. How you want to power it,
and
2. How much EL wire you are powering.
There is more about EL wire here:
http://neonstring.com/index.php?tasket=faq
http://www.neonstring.com/index.php?tasket=videos
