How to Make Emergency Butter Candle
Introduction: How to Make Emergency Butter Candle
In this video tutorial, I will show u make an Emergency Candle from a block of Butter
This candle can burn over 4 hours!
You will need:
  • Salted butter
  • Toilet paper
Step 1: You Will Need a Block of Butter
I use Salted butter
Step 2: Cut the Butter in Half
You can make a candle out of half block of butter
Step 3: Use Toilet Paper As Wick
I tear a section of toilet paper to a square shape
Step 4: Fold Toilet Paper in Half
Hold paper in diamond shape position and fold down, to make a triangle
Step 5: Twist Paper Into a Wick Shape
Roll paper into a tube shape, then twist both end to get a wick shape
Step 6: Ensure Wick Have Sufficient Length
Place wick was L shape in front butter, ensure sufficient length above butter
Step 7: Make Hole in Center
I use a chopstick, make a hold almost to end of butter
Step 8: Insert Wick Into Prepared Hole
With the help of a stick, slowly ease the wick into the hole
Step 9: Spread Butter Over Wick
To help the candle lit properly
Step 10: Lit the Wick With a Lighter
With wick soak in butter, it should burn properly
Step 11: Voila! Butter Candle!
Congrat! You have successfully make an Emergency candle from a block of butter!
Turn off the light to watch it flicker in the dark. :)
Repeat the process with the other half block of butter if u need more candle..
    • Paper Contest 2018
      Paper Contest 2018
    • Pocket-Sized Contest
    • Science of Cooking
      Science of Cooking
    I like this idea but with the price of butter where we live, I think I'd reach for my oranges to make candles first :-) Although if I was completely out of oranges, this would definitely be another good possibility for getting some light happening :-)
    Ingenious! Good use of household materials, especially the chopstick.
