loading
Step 2: Push Down and Turn - 2
Don't put the thumbtack in the center. Put it close to the edge, but not right on the edge. If it's right on the edge, and slips between the caps, it sometimes won't catch the inner cap.
If the outer cap is really hard plastic it can sometimes be difficult to get the thumbtack through. You could just tap it in with a hammer or some other hard object, like that can of lima beans from 1978. On the hard ones, I've found just twisting the thumbtack a little, while putting pressure on it, will get it through pretty easily.
You could just put the thumbtack on the table with the point up. Turn the bottle over and push it straight down onto the tack. If the pressure isn't even, it's easy to bend the thumbtack. To keep the pressure even, just use three thumbtacks. Space them evenly around the edge and push the bottle down on them. Even if only one goes in, that's enough to lock the caps.
The only expense is a thumbtack, and what are those worth? Less than a penny? And it takes all of 15 seconds.
<p>this is awseome it works perfectly and makes complete sense :D</p>
<p>Bless you for this 'ible! I have nasty carpal tunnel, and I can't get the blasted pain relievers open, heh. </p>
<p>I forgot to say my way works for both pills and liquids and doesn't compromise the lid in any way so no chance of contamination of spoiling or leaking and can be reversed if needed</p>
<p>for the ratchet type there's a very simple no effort method with a screwdriver and a candle if anyone is interested. Works every time and requires no force other than taking the top off once and can even be done with the cap on glass and metal conta</p>
Also, for the push-down-and-turn caps, it is actually two caps in one. The outer 'white' cap and an 'inner' cap that is usually translucent. Simply pry/cut the white cap off of the inner cap, and you have your easy-open cap that is still water-tight--which is useful for liquids in bottles. Some pills are really sensitive to moisture as well--they usually have anti-moisture things inside the cap (Tums, or Pepto-Bismol have these) and puncturing them with a thumbtack would not be a good idea. This is where my method shines.
<p>Just a suggestion (that has worked well for me, so far). I use side cutters to remove the outer lid. I have found the side cutters in the following departments - mechanic/tools, electrical, beading, floral. I have even found some at Dollar Tree.</p>
cutting open isnt always easy. What I just did was a simple thing. Hammer the edge of the outer cap...!! Bingo..it just breaks apart leaving the soft inner cap intact!<br>Caution: I did it after opening the bottle - had the cap out of the bottle. Generally I find it easy to open the first time but gets harder later. <br>May be it will be alright to do it with cap on the plastic bottle (not glass) bottle itsef. But, u got to be very careful.
My bottle of Augmentin had a small desiccant capsule along with the pills.
Thanks Spokehedz. I've cut outer caps off before and I think it might be too difficult for people with problems using their hands. I added a technique that is pretty simpler but not as easy as the tack. I just forced a bit of toothpick between the caps and they were suitably locked. It might be difficult for people with arthritis or other hand problems. Maybe they can get a friend to do it for them.
Since you leave the tack in place, there isn't actually an open hole for moisture to get in. If you remove the liner and put the tack in, then bend the tip over with a spoon and put the liner back. then there is still a good seal and the tiny bit of metal isn't exposed inside (I'm sure the liner isn't designed to be a barrier to the metal and it might still eventually corrode or rust under the liner if you use the lid over and over - might want to watch that.) If you are careful, you could just push the tack in far enough to grab the inner lid without piercing all the way through. Just push it in a few millimeters, see if it catches and keep pushing a little further until it fully catches but don't go all the way through. Another way is to go ahead and tack it close to the edge to try to catch the edge of the inner cap but not go through the surface. If you miss, you could just try again a little closer to the center. The side walls of the inner cap are wide enough that you should be able to get the tack to enter the side without actually piercing it and coming out inside. It's more complicated though. This was the quick and dirty technique. It's a good idea to leave those silica packs inside to keep the moisture down. Moisture could eventually rust the tiny tip of the tack and I wouldn't want it to contaminate the medicine. That's why I didn't recommend it for liquids.
<p>I found something similar, just screw a small 1/2 screw into the top, also about one or two tenths or so from the edge ---- its easy to screw it in and it stays there and you can put it on any bottle - now it takes only half a second to open, easy, with no effort</p><p>==== </p>
<p>i have some buckleys pills and i cant open the blister pack without bursting the capsules we all know how &quot;great&quot; buckleys tastes so any ideas anyone????? this is the only site iv'e found with any advice on child proof packaging</p>
<p>I open the back of the blister pack with the pointy end of a metal nail file.</p>
<p>I keep a cheap little retractable utility knife in my bathroom cabinet. When I need to open a blister pack, I just carefully slit the backing at the very edge of the blister with the tip of the knife - put the pack on the counter rather than holding it in your hand, and put your thumb-tip on the capsule so it doesn't move around and get under the knife. I cut about halfway round the blister and lift the backing up with the knife tip. I've never bought Buckleys so I don't know exactly what their packaging is like but I especially hate the blister packs where you have to peel off the backing instead of pushing through thin foil!</p>
<p>Do you have arthritis so you can't open the bottle or is it just too hard.I don't have arthritis and i tried to open aquarium bacteria conditioner and followed the push and turn instructions but it is impossible. But, then i figured out how to open it. You need to push it very hard and spin as fastest as you can- especially if if is the first time you opened that bottle.</p>
<p>I used pushpins instead and it works. Thank you! You saved my hands from hurting!</p>
<p>Push-down and twist caps will open without push down when using channel lock pliers. (everyone should have channel lock pliers) Just squeeze tighter until it opens. Works with most other styles of lids as well.</p>
This was the best instructable yet. How many of us experience frustration over this modern convenience!
Thank you very much for your post on how to defeat the &quot;Evil Childproof caps&quot;! There are no children in the house here, and to me, there's nothing more horrible than waking up with a migraine, not wanting to turn lights on to line up the darned little arrows on the cap and bottle because my head hurts really bad already, but having no choice because of having to line up those darned little arrows! Your instructions on getting rid of that darned little tab on the inside were great! Thank you very much for that! I did want to let you know though, that after I had the one scraped completely off, I still had problems. I took a good look at the inside of the cap and found that there were actually 2 more little tabs on the inside, almost across from the arrow. I scraped those darned things off and VOILA!!!! No more problems with the cap! Thank you again. Your instructions are greatly appreciated.
Whoever put childproof lids on arthritis pills has a sick sick mind....so much help dude :D
Thankyou so much. I had some brand new vitamins which i could not for the life of me open, I think the saftey cap may have been broken. Your thumb tack tip worked a treat.
Thanks! I saw the wallet card about this at Maker Faire and picked up enough cards for my whole Parkinson's Disease support group. It's especially helpful because so many insurance companies now insist that you order drugs by mail, online -- no more asking your friendly neighborhood pharmacist to give you non-patient-proof caps in the first place. <br><br>Note that there's now another form of reversible/self-modifying cap: looks like the double lid type you disable with a thumbtack, but in this case you push down on the center of the top lid and it collapses onto the inner one. If you'd like an example for the next revision of this Instructable please let me know.
I found out how to open child proof bottles when i was 5.... //.O X(♫ S&sub;R&exist;AM◯♫ )X
FANTASTIC! Thank you
OMG THANK YOU SO MUCH! I just wasted an hour and messed my hands trying to open this stupid bloody nail polish remover but your thumb tack trick was awesome! I even managed to rip the first lid off the bottle only to find that there was a seccond :( Thanks again!
I'm gonna try this! I am so fed up of fighting with pill and lemonade bottles....yes I am weak. You could just move into my kitchen and live in my cupboard lol!
I tried this one, but i kept knocking the bottle over and spilt the contents-your help in this matter is really appreciated-I have arthritis and I struggle with med caps
Take the lid off of the bottle and place it on a firm surface. <br /> <br /> To keep it from sliding on a hard surface you can put down a damp wash rag (or a dry one but a damp one sticks better) and put the cap on that. Hammer the tack in with the cap by itself on the washcloth. <br /> <br /> Keep that cap and use it again when you buy new medications.<br />
now how to plug something in an childproof outlet,IT'S IMPOSSIBLE,FOR GOD'S SAKE!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!or it may be that im a child,but i can outsmart electricians
I've finally figured out how to and applied it on my extension cord.<br />
Outsmart electricians????
yes because they make mistakes like wiring neutral to hot supply,using wrong colors and not using the correct breaker,my electrical work is more delicate and safer.
Somwtimes wrong colors cannot be helped. My dad is an electrician, and colorblind.
I'll let it pass for colorblind people.
Oh, yeah, I know about the wire color codes and of that sort of stuff, <em>AND</em> the safety of high voltage.<br/>
the safety only comes with the proper precautions,if no precautions=&lt;Homer voice&gt;Ooooooowwwwwww!&lt;/homer voice&gt;<br/>
Lol!
i admit it was funny
:D
:D
HTML-esque tabs for homer voice. Nice.
Derin what can u expect from Electricians in turkey. The stupid guy replaced our cables with a higher gauge wire! and guess what the system shorted out
or screw the pills cap upside down , instead regular way, flipped, you will be able to open as pop and kid will look at it as IS EVIL!!!! is upside down, uuuu!!!!
This is fine if you can get the cap off in the first place. However with caps like those on toilet bowl cleaners it doesn't quite work. I took a pair of small wire cutters and clipped off the tabs.
Wire cutters are great also. I wanted to show a tool that almost everyone has available.
I have osteo -arthritis, opening lids can be painful. thanks for sharing your idea.
You are very welcome.
Newer caps are one piece and I haven't figured out an easy way to do them. I'd just use needle nose and bend them outwards. Being flexible is what it's about.
Hi SFHandyman. Do you give handyman lessons to husbands? Pleeeeeeeeeeease ?? ;0)
About This Instructable
253,131views
20favorites
License:
Bio: ''If you haven't seen my Instructables, or comments, you might not know I have Onanon Disease. I go On 'n', On 'n', On...'' My ... More »
More by SFHandyman:How to make Soft Drinks 3d Instructables Robot - Sketchup Restored Family Photo Cards
Add instructable to:
