Remove these ads by
Signing UpStep 1What you'll need
-5' x 5' bag of welding blanket........$12.00
-Scissors
-Scotch Tape
-Pair of 26" dog chains...$1.86 per dog chain at Walmart
-Eye bolts, along with 4 washers that are atleast an inch thick and fit around the eyebolts...something like $1.00 per eye bolt, and 25 cents for each washer
-2 stainless steel quicklinks...should be about $3.00 even for a package of two of them at Walmart
-a power drill, with a drill bit that measures the same diameter as your eyebolts...it helps when your roommate is a carpenter/construction worker
-Patience
White gas scares me for this application. i think it looks nice but is very very dangerous. it flashes lower than kerosene and atomises very easily. I would avoid it if possible. I do understand instances where it might be best.
I am more of a staff kind of guy anyway but I like seeing how others make their stuff since I tend to be the one making the gear for our performance group.
Brilliant move using the fire blanket for the wicks. I usually use cotton belt webbing, but I imagine the blanket would soak up more fuel.
Good 'ible!
Welding blanket is good and cheap to practice with, but when you start up with doing performances, make sure to get some professional grade kevlar. ;)
I have been performing as a poi/staff spinner for over 5 years now! I make all of my tools by hand. Love the dog chain idea. Welded links and o rings made to take a good tugging. Not a fan of kevlar- Doesn't soak up enough fluid. As long as you put them out before they go dry cotton burns longer and lasts almost as long.
And at the price of cotton, I can replace spent wicks without taking a big wallet hit.
Thanks for the response!
