3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
How to make Green Fire.
video How to make Green Fire.
Mix Heet Antifreeze, with Boric Acid (commonly found as roach killer), and light!
Its that easy.
But why does this happen?
Because, Boric Acid is a boron containing compound... Any boron-containing compound will cause flames to emit a green colour.
When boron compounds are heated, electrons absorb a certain amount of heat energy that causes them to jump to higher energy levels. After some time, the electrons lose this energy and fall back down to their original levels, emitting this energy in the form of light. Because the energy absorbed by electrons is different per element, each element will give a different colour.
20 comments
Jun 21, 2009. 11:51 AMEvilblaze says:
Why does this happens? Not correct. Boric acid and methanol forms boric acid methyl ester and when this ester burns, than it will cause this light. It also works with ethanol, but than you should add some cc sulfuric acid as a catalyst to form boric acid ethyl ester.
Sep 16, 2011. 1:29 PMbentcyclist says:
Please change your than to then.
Sep 14, 2011. 9:17 AMamaziliauskas says:
do you have to use heet antifreeze or i can use other antifreeze?
May 7, 2011. 9:50 PMthelastonekills says:
this is cool!! 5/5
Oct 2, 2010. 8:19 AMtranoxx says:
How long will it burn for?
Apr 22, 2010. 5:56 AMluka1184 says:
How can and do you even learn how to guess what things in both scince, technology, electronically and substances and WHATEVR, which can work together? And how the hell did the first sciencetists found out and learned it?
I need to make Withccraft fake flames for fun, only to expereince. I'am not really interesting in it like that.
Cya my friends!
PS I would apreciate a FAST and EASY way to learn this, AT HOME ;D Bye bye, and live on happily.
Jul 23, 2009. 10:53 AMthartaros says:
does the fire create toxic fumes? because as far as i know you're burning two chemicals that can kill humans. also is there a way to make this into candle form, or maybe like an oil lamp?
Mar 7, 2010. 8:48 PMTechNerd1012 says:
If it does create toxic fumes, as long as you do it outside, you should be fine (given that youre not mutting your face right over it and breathing it in deeply)
as for the oil lamp, you could probably just put this mixture into the part of the lamp where the oil goes
Jul 2, 2009. 10:25 AMFuyuKitsune says:
My trick is mixing isopropyl alcohol (rubbing alcohol) and sugar. The sugar burns blue and the alcohol burns yellow, but it's not as cool as this. That bright-green is sweet.
Jul 19, 2009. 9:16 PMgorgo333 says:
that doesnt work.
Sep 19, 2009. 2:14 PMFuyuKitsune says:
oh, the alcohol burns blue :P sorry the only liquid I can think of that burns yellow is gas. Ima try that later
Sep 19, 2009. 1:35 PMd2j5 says:
wont...that like kill you? under boric acid it said roch killer........
Jul 26, 2009. 12:56 PMspotty mcgee says:
would burning copper salts produce the same results from a much safer compound that isn't deadly.
Aug 27, 2009. 7:40 PMVIRON says:
Boric Acid is similarly toxic as salt, except that people have no reason to eat it. It kills bugs in hair and fungus on skin. It kills bugs by making them unable to eat. It is probably the weakest acid. Salt kills earthworms and slugs. Copper dust or thin wires do make fire green too.
Aug 11, 2009. 5:36 PMbuckminsterfullerene says:
yeah, it probably would. Since the copper (or copper compound) in the crystal is bound by electrons basically 'magnetized' to protons of the other compound, you could probably dissolve as much of the salt as you can in almost boiling water and then burn it
Jun 24, 2009. 8:31 PMiLikeCoolStuf says:
ROFL!!!
Jun 15, 2009. 9:17 AMtailboy says:
thats pretty neat!
Jun 13, 2009. 6:29 AM___ says:
Cool!
Jun 13, 2009. 2:06 AMwestfw says:
"Heet Antifreeze" (actually, isn't it more a de-watering agent for gasoline?) is Pretty pure methyl alcohol. My understanding is that the alcohol actually reacts with the boric acid to produce methyl borate, which is both flammable and soluble in the alcohol, which makes this work much better than other similar demonstrations.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
9
Author:iMac
