3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
How to make Gymnastics/Fitness Rings from PVC Conduit
Step 4Heat pipe in oven
Heat pipe in oven
My oven wasn't large enough to fit the pipe so I did performed the following steps for each pipe:
1) heat for 5 minutes (other end was sticking out)
2) rotate pipe so other end is sticking out
3) heat for 5 minutes
4) bend pipe into horseshoe shape and keep the shape by using wire (I bent an old coat hanger). I could now close the oven door!
5) close oven door and heat for 5 minutes
Make sure you watch the pipe to make sure it doesn't turn brown! We want our cakes and breads to turn brown -- not our pipes. You may need to vary the temperature and keep an eye on it.
5 comments
Jun 3, 2009. 7:43 AMteeroy65 says:
What temperature range did you use?
Oct 14, 2009. 12:46 PMgodspiral says:
any burning smell at that temperature ?
It starts to soften at about 170F.  I'd use 300F, but if it didn'tsmell up, then ur prob fine.
Feb 20, 2009. 9:26 AMaaronnielsen says:
It is easier to heat the sand up and then put hot sand into the pipe. This can be done by putting a few quarts of sand into a pan and heating to about 350 degrees on a camp stove or on your gas range. Tape one end of the pipe as described and pour sand into the pipe. Empty the sand after about a minute. This will have preheated the pipe. Then pour sand in again, and tape the other end. In about a minute your pipe will be very rubbery. now you can bend your pipe at will. The pipe will cool quicker if you can get the sand out.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:Mr.F
