It is a simple process of infusing flowers, herbs or spices into an oil by heating or letting it sit in a sunny spot so that the volatile oils can transfer into the carrier oil. I will show you how I make them in this instructable.
Step 1: Materials:
- Oil (I will discuss the different types to use in Steps 2 and 5)
- Herbs, spices, flowers
- Clean, dry glass jars
- Clean decorative glass containers
- Coffee filters, cheesecloth, sieve
- Funnel
- Spoon
- Hot plate/double boiler or pan/skillet
- Mortar and pestle
- Sunny windowsill
As you will see in the following steps a wide assortment of flowers, herbs and spices can be used in making infused oils. Since you will ingesting or putting these oils on your body I would recommend using organic material if you can. Better still if you can grow them in your garden, you can control what goes on the plants as well as save yourself a lot of money too. Even a little potted herb plant on your windowsill will do.
Step 2: Culinary oil: preparing herbs
Here a few suggestions, don't be afraid to mix and match:
Basil |
Clove |
Oregano |
Peppercorns |
Garlic |
Rosemary |
Tarragon |
Sage |
Chilies |
Coriander |
Thyme |
Cumin |
The best type of oil to use is extra virgin olive oil, you can also use grape seed , peanut or sunflower oil. Walnut oil is also good if it will be used cold such as for salad dressings since it is not good for heating.
How to make:
- Wash your herbs and dry completely**
- Bruise or rub herbs, for spices toast them to bring out the flavour
- Place in a clean dry glass jar.
- Add oil until it completely covers the herbs/spices.
- Place a lid on the jar and close
- Place the jar on a sunny windowsill or other sunny spot. Swirl or shake the jar every day or so.
**It is important that no moisture is introduced into the oil as it can become rancid or prone to mold or bacteria growth. (Garlic is particularly prone to this so it should be stored in the fridge or made with the heating method in a skillet described in step 4.)
Step 3: Culinary Oil:draining and storing
- After a week drain off the oil into a clean dry jar using a sieve (for larger herbs) or cheesecloth or coffee filters.
- Taste the oil to see if the flavour is strong enough
- If you want it stronger add more herbs/spices to the oil, close the lid and place back in the sunny spot for another week.
- Repeat as needed.
- If you are happy with the flavour, pour the oil into a nice glass bottle, you can also add a fresh sprig of herb to make if look fancy.
- Store in a cool dry place or better still, in the refrigerator.
Step 4: Culinary Oil: Heating method
- Grind dried herbs/spices with mortar and pestle
- Place into a clean glass jar
- Cover in oil
- Place a lid on top of the jar (don't tighten)
- Place the jar on hot plate and simmer for several hours (about 3hrs - warning: your kitchen will smell wonderful!)
- Taste to see if the flavour is strong enough
- Drain with a sieve or cheesecloth/coffee filters
- Pour into a clean glass bottle, label and store.
Step 5: Massage, bath and scent oils
Sweet almond oil |
Evening primrose oil |
Jojoba oil |
Avocado oil |
Apricot kernel oil |
Borage Seed Oil |
Olive oil |
Various nut oils (eg walnut,pecan, hazelnut) |
Grape seed oil |
Various seed oils (eg hemp,sesame, sunflower) |
These oils are easily absorbed into the skin (making them great moisturizers) and do not have a strong odor. They can be bought at health/natural food stores or specialty aromatherapy stores. Some can be found at grocery stores, but try to get cold pressed oils.
The type of flowers or herbs that you can use is really up to your imagination or what you happen to have growing in your garden, here are some suggestions:
Lavender |
Rose, carnation, chamomile, jasmine, violets |
Comfrey |
Geranium, violets, lily, sweet pea, hyacinths etc |
Clove |
Vanilla bean |
Citrus peel |
Cinnamon bark |
Calendula |
Lemongrass |
Pine |
Mint |
Using fresh over dried is usually better, also if you are getting them from your garden, cut the flowers/herbs in the morning and start making the infused oil right away if you can. You can mix different flowers and herbs together creating a variety of different scent combinations. The instructions for making scent infused oils are basically the same as culinary oils, though I wouldn't recommend using the heating method since flowers are more delicate than culinary herbs.
How to make:
- Gently bruise, crush, or chop the flower petals, herbs, spices or peels
- Place them into clean dry glass jar
- Cover them in a carrier oil
- Place jar in a sunny spot. Swirl or shake the jar every day or so.
Step 6: Drain and store
- After a week drain off the oil into a clean jar using a sieve or cheesecloth/coffee filters.
- Smell the oil to see if the scent is strong enough
- If you want it stronger add more flowers(or herbs etc) to the oil, close lid and place back in the sunny spot for another week.
- Repeat as needed.
- If you are happy with the scent pour the oil in to a nice glass bottle and label. You can add a pretty ribbon and give it as a gift.
Visit Our Store »
Go Pro Today »
From left to right: Green Peppercorns, Chilipepper, Rosemary, Cinnamon, Garlic.
pls help.,....thanks!
is it possible to mix dry herbs since i originally processed fresh herbs (i saw dried sage and bay leaves in the supermarket) ?
or should i drain the leaves (oregano and basil) before mixing the dried ones?
i also found methyl salicylate in a drugstore (with labels like: 65ml methyl salicilate, 35ml mineral oil) and it smells good (minty smell), is it safe to add this? ( its even indicated in the bottle that its oil of wintergreen -antirheumatic)
i am also bothered whats the best thing to do, if to store it in a dry cool dark place or to place it where it can really be spotted by the sun...what i do is put it in direct sunlight for 20-30 minutes in the morning, is this ok? by the way, my bottle is clear so i wrapped it with a dark colored plastic bag.
i tried putting the oregano-basil infused oil in my skin and it feels really good, but im just bothered with the smell... i hope you could help me with this questions before i share it with mom and dad ;)
Thank you in advance....
2) methyl salicylate smells nice and is used in sore muscle creams but it is also toxic so only use small amounts (see the wiki article).
3)Only leave in a sunny spot while the herbs are steeping, once you drain off the herbs you should store in a dry cool place.
3)If you don't like the smell try adding something with a smell that you like.
ok then, il try to put some drops of methyl on it. :)
and try to look for fragrance oils that's good for the skin... :)
one last (i hope so) is it also save to mix ethyl alcohol? just wonderin ;)
ill take your advise on putting dried bay and sage, il let you know how the smell would turn out in a couple of days ;)
thanks again ;)
I also love that you've included the massage oil/botanical oils. Now I can smell good and cook with delicious oils! Have you tried lavender? I have not but am curious to see what it smells like in an oil base...
Other sites I have seen also say to store it cold. So if you boil it first, let it cool then into the fridge, you should be safe
This way you can take advantage of the heat of the sun but not the light.
Very nice instructable.
I'm sure it depends on what they are infused with, but how long will these keep for?
