Introduction: How to Make Kilju
Picture of How to Make Kilju
Warning:I do not take any responsibility if you hurt yourself etc. Kilju contains alcohol so make it only if you are over 21
Kilju is a traditional finnish alcohol drink
It's made of sugar, yeast and water
It's illegal to make Kilju in Finland but it might be LEGAL in YOUR country ;)
Step 1: Ingredients
Picture of Ingredients
1 Bottle (at least 1,5 litres )
2 Dl sugar
2 teaspoons yeast
1 litre water
Mix all ingredients into the bottle.
The water should not be warmer that +30 degrees because the yeast "dies"
Here's a picture of the indgredients (well you don't really need the mushroom, it only symbolises the yeast =D )
Step 2: The Processing
Picture of The Processing
So basically it takes about 4-8 days to complete the process.
after the processing it should be 6-16 % ethanol.
when you close bottles cork, _DO_NOT_ screw it tighly because it needs to get some air, without it the whole thing is going to explode. There may be some steams comign from the bottle which may be stinky so place the bottle on a well ventilated place (outside if its summer)
if the cork is too tight, this happens =(
Step 3: Preparing the Drink
Picture of Preparing the Drink
next, pour the mixture from the bottle through a Pantyhose (it seperates the yeast and other crap from the drinkable things)or let coffeemaker seperate it ( do not switch the coffee maker on!)
remeber to have a can,jug or whatever where you store the drink ;)
Kilju is drinkable for 2-7 days
Step 4: Ideas
Picture of Ideas
Heres some tips when drinking kilju
Serve kilju as Cold as possible!
You can also mix some juices on it
Use your imagination ;)!
Kuuppax made it! (author)2014-11-18
I replied to a comment, but I'll add this here as well so everyone can see it.
Kilju is safe to use, but if you want to be completely sure I'm sure there are tools to measuring methanol.
The instructions on this website aren't that good, actually they suck, get a fermenter ( 30 liter bucket with a small hole for the trap ) and a water-trap for it so the air passes through but can't get back in, costs like 12 bucks plus trap is 2 bucks.
25 liters of water, 6 kilograms of sugar ( brewing sugar is the best I think you can buy it online with the other stuff ), after that few liters of SELF MADE juice, no don't buy that stuff from the store, it's prob not even juice at all costs prob 8 bucks.
Also don't go for the normal yeast, buy super yeast that is made for alcohol, the normal yeast is optimal for baking and stuff, super yeast = 3 - 5 bucks.
So now you wait for 7 - 10 days, ( yeah someone over here will be like "dude cmoon you can wait for 3 - 5 days, but better be safe and sure than risky since the whole thing is going off the window if you add the chemicals too early that stop the alcohol progress and eliminate the yeast and most of the sugar in the water ( oh yeah you need to mix it up a bit from time to time ) hasn't turned into alcohol yet so it tastes like a bad sugar lime ).
The day or two before you're going to drink it, taste it a bit that does it have alcohol in it and pour the chemicals in ( that are safe to use ) that take the taste of yeast away and stop the progress and can be bought online like 50 cents a piece. Also add handful of lemon slices to add some taste.
After this you need a burdock AKA a small tube also you need another bucket(s) or bottles, you're doing this again in order to get rid of the yeast at the bottom of the fermenter and the chemicals forced the yeast to the bottom, but if you touch the yeast even a lil bit it goes off and the drink tastes like yeast again in other words horrible.
So you need to place the bucket to a high ground, could be ideal to place before you add the chemicals and place the tube in the fermenter and the other end to the other bucket which is on a lower ground, now you suck the tube a bit until you feel the alcohol coming and because of physics and pressure the fermenter will be completely dry in few minutes, just keep the tube on the alcohol so it keeps sucking it, also note that they can't be too far away from each other so the tube doesn't run out,
because it really sucks that there's still a bit of alcohol at the bottom but it's almost impossible to get since the pressure trick doesn't work anymore and with a spoon etc... the yeast would go off and it would taste horrible.
Now at last it's drinkable and tastes good =D You can make make it juicy like I do or add other juices/berries to make it home made wine =D Have fun!
ScottF28 (author)Kuuppax2015-09-26
The instructions here are fine. Short of using an ideal yeast you don't need chemicals or gauges. Just give a small taste every day or two until carbonation is over and there you go. White granulated sugar and wine yeast are fine. A glass soda bottle is fine.
thefreshlettuce (author)2008-11-27
I am pretty interested in making some of this stuff, but would like some reassurance. I've heard that when making moonshine, you produce methanol, and have to be very careful not to consume it, or you go blind. It is my belief that since this concoction has no fruit in it, that methanol cannot be produced (I've read that somewhere...) Anyway! I am very fond of my eyesight, and hope someone can give me some information about the safety of drinking this.
Kuuppax (author)thefreshlettuce2014-11-18
Many of my friends make it and it's completely safe to use and it always cheers up when at the start of month there's a homemade alcohol party where everybody can enjoy for almost free of charge especially when the beer around here isn't cheap.
Btw the instructions on this website are horrible, get a fermenter ( 30 liter bucket with a small hole for the trap ) and a water-trap for it so the air passes through but can't get back in, costs like 12 bucks plus trap is 2 bucks.
So now you wait for 7 - 10 days, ( yes someone over here will be like "dude cmoon you can wait for 3 - 5 days, but better be safe and sure than risky since the whole thing is going off the window if you add the chemicals too early that stop the alcohol progress and eliminate the yeast, which tastes really bad )-
So you need to place the bucket to a high ground, could be ideal to place before you add the chemicals and place the tube in the fermenter and the other end to the other bucket which is on a lower ground, now you suck the tube a bit until you feel the alcohol coming and because of physics and pressure the fermenter will be completely dry in few minutes because the flow doesn't end.
you only go blind from drinking bady' distilled spirits. You have to distill to make methanol.
jeesus (author)thefreshlettuce2009-08-14
It couldnt be any safer to drink.
Tomma (author)thefreshlettuce2008-12-19
hey, Well. after drinking this, i did not go blind, hoewer i don't take any resposibility if you do. But i'd say that you should try this if you want.
ninjatesshin (author)2012-01-18
I come from Finland happy that you Americans think of the Finnish tradition of drinking
"I forget, is it ethanol or methanol that makes you blind? ;-)"
-miserslippy
ethanol=alcohol
metanol=that poison
You can remove the methanol boiling drink pontikka (finnish moonshine) and discarded the first deciliter (methanol evaporates from 65 ° C for ethanol, but only 85 degrees Celsius, or methanol comes first)
sorry my bad english!!!!!!!
MisterSlippy (author)2008-02-14
MrJM (author)MisterSlippy2010-10-12
Do beer goggles count?
unidyne (author)MisterSlippy2010-07-26
Methanol is what you should avoid. That's methyl alcohol, wood alcohol, wood naphtha or wood spirits. And if it doesn't kill you, will probably leave you blind. Ethanol, on the other hand, also known as ethyl alcohol, pure alcohol, grain alcohol, or drinking alcohol, is what's in those bottles at the bar. If you get confused, just think of Lucy and Desi's neighbors, Fred and Ethyl. Rubbing alcohol is often ethanol, denatured (so you can't drink it) with either methanol, acetone, or both.
drummonkey92 (author)2008-02-11
hi, sorry, but wat's 'DI' as in "2 DI sugar" thanks
unidyne (author)drummonkey922010-08-22
2 deciliters = 200 milliliters = 6.76 ounces (fluid)
baxxter95 (author)2009-08-24
Ihme että täälläkin suomalaisia :P
nobody_95 (author)baxxter952009-12-03
Sitä samaa. Kirjotin tohon hakuun booze ja repesin kun näin että ''How to make kilju''
Oh, and a couple of tips on making alcohol on the cheap: Wine makers use an airlock to allow the yeast to ferment without letting air in, and without allowing a dangerous pressure buildup. You can achieve the same ends with a balloon, the neck of which is stretched over the container. This allows the fermentation process to give off CO2 without risking an explosion - just remember to let the gas out of the balloon a couple of times a day! The balloon is also a good indicator of when fermentation has completed - when the yeast is dead, it stops giving off gas and the balloon stops inflating! You can make your finished product stronger without setting up a complicated still by putting it in the freezer. Water melts at 0 degrees centigrade, while alcohol melts at something like -20 degrees. So long as your freezer doesn't drop below -15 or so, the water will freeze off, whilst the alcohol will remain liquid. Leave it in the freezer for a week or so, removing the ice each day, and you should end up with 2 or 3 times the alcohol content you started with. The finished product from this process is also handy for fuelling spirit burners and zippo lighters, as well as for cleaning wounds and degreasing metal. I wouldn't recommend drinking it, though!
jeesus (author)MisterSlippy2009-08-14
Melting point of ethanol is −114.3 °C. I wouldnt use that freeze liquid for cleaning because it cointains impurities. Using it to fuel zippo lighters might ruin them because alcohol vaporizes easier than water leaving cotton inside lighter wet.
deth2all (author)MisterSlippy2008-04-11
instead of letting out pressure a few times a day, just poke a small hole in the balloon, thats what i do and it works great
MisterSlippy (author)deth2all2008-04-12
Good call, and I wish I'd thought of that! I was making some sloe wine a couple of years ago, forgot to relieve pressure in the balloons and, well, it took a couple days to get all the fermented sloe-berry juice off the walls, ceiling etc. A pinhole would have stopped that.
Fieldownage (author)2009-05-15
Mukavaa työtä!
jaysbob (author)2008-04-03
next up: "Make pruno, the old fashioned way!!" I like the paint pictures.
hammerhead (author)2008-02-12
Oh man, it takes some hair on the chest to drink this stuff. My dad used to make this with regular breadyeast (2 weeks fermentation, 25 litres) and it tasted like the devils bumhole. And by the way, this is the raw product used for production of alcohol and owning an apparatus for distilling, and the use of it, is prohibited in many countries.
flactemnad (author)2008-02-12
dL = deci Liters = 1/10 liter = 100 milliliters
2 dL = 200 milliliters
Too bad our American educational system doesn't teach the metric system more, since these are simple standards. For instance take a look at the differences between common measurements on this wikipedia page - all could be equal with a metric system.
http://en.wikipedia.org/wiki/Cooking_weights_and_measures#Metric_measures
About This Instructable
32,318views
12favorites
License:
More by Tomma:How to get World of Warcraft Epic Flying MountHow to make Kilju
Add instructable to:
