I chose to make this Instructable as I was unable to find a device similar to this available for purchase
A Video of it in action is attached as it takes too long to convert. You probably need Quicktime or VLC.
The controller uses a 12V SLA battery and a transistor to control when the lights should be active by monitoring the speaker output. It works best when wired to a subwoofer as it only activates the lights when a beat is present.
You will need:
A box to put it in (I used an old Pioneer home theater speaker)
A Heavy Duty Transistor( The transistor I used was a ST W14NC50 from an old Compaq power supply unit)
Wire
A soldering iron
A switch (optional)
3 Speaker input ports(don't know what their actually called)
A 12 Battery. (Make sure the voltage isn't to high over 12V as you may blow the LED's)
MOV050.3gp5 MB
Remove these ads by
Signing UpStep 1Constructing and soldering the circuit
emotec
http://download.cnet.com/FormatFactory/3000-2194_4-10968547.html?tag=mncol;1 Using this only took about 40 secs to make your video into .avi format that will play on windows media player. I have attached the result to this comment so it's ready for other readers to view. You have my permision to cut it from my comment and add it to your instructable if you like!!Also, I agree that you should add a voltage regulation curcuit to your design between your battery negitive and your transister to prevent an overload to your leds and burning them out prematurely. Otherwise,nice able! Happy brainstroming!
Quote of the day--"Pirates are always cooler than Ninjas"
G'day mates
Emotec
anyway great instructible! I will definatly look into building this for my soon-to-be sub system for my car
