Maximum current is about 650 milliamps. The circuit is designed for batteries of 900mah or higher. Power source can be a 12v Gell cell (Power panel), or can be powered by a car's cigarette lighter.
I use an old 12v DC wall transformer (800ma or more.)
Remove these ads by
Signing UpStep 1The Schematic
LM317 variable regulator
2N2222A or any Transistor handles 800mA
2 Capacitors 0.1 uf
1K POT
1ohm 1Watt resistor ( current limitor )
Adjust R4 to the required output voltage
R1 controls the output current
What do do you need a 15amp lithium pack for anyways? lmao, just wondering.
& I'm just wondering how this circuit works. What's the purpose of Q1? I know what the regulator does, just confused about Q1.
1. Check the voltages of each cell to make sure they are above 3 volts. Do not use this charger if your cells are below 3 volts.
2. If you are charging 2 cells, make sure the voltages match, otherwise charge each cell individually.
3. If you are charging 1 cell, set the voltage (via the potentiometer) to 4.2 (or 4.1 to be super safe) volts before connecting the battery.
4. Check the resistance of the one ohm resistor to make sure it actually is 1 ohm, or charging current may be increased. 1 ohm will yield approx. 600mA
5. The battery will never fully charge. As the battery charges, it draws less current. So if your voltage is set correctly, you should have no problems with overcharge.
There are many ICs designed for that purpose. 1555 1811 etc...
over current=fire
out of balance condition=fire
overdischarge=damaged battery
use a real charger
not waching the battery =fire
being stupid = fire
This circuit may work fine for lead acid batteries but, for lithium, you're quite literally playing with fire.
I *strongly* advise anybody considering making this circuit to do their research on lithium battery chargers first.
Powerstream has a good how-to on charging lithium-ion batteries, which I've done by hand successfully many times. It takes an adjustable power supply and two meters, so you can monitor voltage and current simultaneously.
The circuit detailed here will cap the voltage, and if you use it with an appropriately small wall-wart that'll limit the current too, but you still need to monitor the current drop and disconnect the charger manually. Leaving it connected will destroy the battery, period.
Very helpful, it explains pretty much all we need to know in regards to charging the little chaps, then you can decide whether the charger is suited to your job. Or youll atleast be able to understand everything thats going on.
