Anyways, I have wanted some gymnastic rings for different kinds of pullups, pushups and reverse rows. They are a great piece of fitness equipment. You can buy them from Elite rings for $80 or make them for a fraction of the price. Here's how I did it.
Remove these ads by
Signing UpStep 1What you need & Prices
2 x 12 feet lashing straps (Harbor Freight Tools: $3.99)
20 feet of 244 lb capacity nylon rope (Harbor Freight Tools: $1.47)
2x 1" x 24" pvc pipe (Home Depot: $1.43 each)
Duct tape
Twine
An oven
Sand
A 1 gallon paint can
![[Collegiate Exercise] Dorm Room Fitness](http://img.instructables.com/files/deriv/FPR/85RY/GPBDG81Y/FPR85RYGPBDG81Y.SQUARE.jpg)
I've tried it with some polypropylene pipe at 200C (~390F) for 10 minutes, when I took it out of the oven I couldn't get more than a very slight bend in it, it was very soft though, as the ends I was holding basically ended up crushed, so it was very easy to deform the circular shape but not to bend it around anythng.
Does anyone know if I need to leave it in longer, at a higher temp or if polypropylene is just not suitable?
Thanks.
To avoid melting the PVC, I heated the oven to 200F instead of 350F. Since the melting point of PVC is approximatly 210 degrees F and the vicat softening point is 185 degrees F, the PVC is in a state between solid and liquid at 200F where it become flexible as rubber.
I think there is a little problem in the design. The friction between the forearm and the edge of the tube is painful. I think the best would be to do a full circle with the tube (like in the other instructable about gymnastic PVC ring) and put some tape between the two extremities of the tube to mask the cutting edge and to make a full ring. Then I would drill two holes in the full ring to pass the rope inside the ring.
http://www.instructables.com/id/How_to_make_GymnasticsFitness_Rings_from_PVC_Cond/
