Introduction: How to Make "Temple of Demise" Knex Ball Machine
Picture of How to Make "Temple of Demise" Knex Ball Machine
This is Tornado 96 and this is an instructable for the first of my ball machines on this site. It is called Temple of demise. Feel free to ask questions and make comments. This ball machine uses a lot of pieces so i decided not to make a piece count. Sorry.
Unluckily I couldn't upload the video. Now that you've seen the pictures it is time to get started!
Step 1: The Base
Picture of The Base
This is a very important part of the model. Everything connects to this. I wonder if it would still work without it? I hope you notice how everything is placed
Step 2: The Tower's Base
Picture of The Tower's Base
This is where all the action starts. If you don't have red gears you can replace it with a yellow gears but you would have to fiddle around with the spacers. Please tell me if it is hard to understand the angle of the 3-D connectors.
Step 3: The First Receiver
Picture of The First Receiver
The receivers are the paths that take the balls back to the chain lift. There are three in total.
Step 4: The Second Receiver
Picture of The Second Receiver
This is the second receiver which is placed on the left side of the construction.
Step 5: The Third Receiver
Picture of The Third Receiver
This is the third and last receiver. This receiver is placed on the left side of the construction.
Step 6: Main Structure - Bottom
Picture of Main Structure - Bottom
The main structure keeps everything strong and steady.
Step 7: Maze and Wheel
Picture of Maze and Wheel
The model is a bit boring. Lets start adding some of the elements! First build the maze and attach it. Then build the wheel and attach it.
Step 8: The Tower
This is where the chain takes the ball up to the top. This part also includes the path separators.
Step 9: Spiral Staircase
Picture of Spiral Staircase
I'm not sure why i gave the spiral staircase a whole step. Anyway, all you have to dodo is make and attach and path 2 is complete.
Step 10: Main Structure - Right Side
Picture of Main Structure - Right Side
Yet more structure. With out this the contraption might not work. This is the most boring part of this ball machine and there is still one left.
Step 11: Main Structure - Left Side
Picture of Main Structure - Left Side
This is the last main structure. Hooray! After this part the rest of the instructable is building elements which is the fun part.
Step 12: The Chain Path and Pendulum Slide
Picture of The Chain Path and Pendulum Slide
Now that you've finally finished the structure it is time for the elements! These elements are both part of path 4. Look carefully for which spacers to use on the pendulum slide.
Step 13: The Orange Path
Picture of The Orange Path
Your almost done. This is the orange path which is the main element in path 3. When your done just add the track. The length of the big ball factory tubing is long enough on the inside but you will have to add a bit to the outside. If the ball gets stuck at the end just move the tabbed connector a bit.
Step 14: Motor Attachment
Picture of Motor Attachment
In this model I used a plug in motor but I'm sure you'd be able to replace it with a any other motor or a crank if you don't have a motor.
Step 15: Chain Attachment
Picture of Chain Attachment
For this part you will need 75 chain links. Divide them into 3 sets of 25 chain links.
Step 16:
Picture of
Congratulations! you have finished building temple of demise. Only the original red and yellow balls work. Any other ball will be too big for some parts of the contraption. If you built everything right it should never fall of the track. I hope you enjoy it!
knexpert#10829476 (author)2013-11-04
The last time I built this, the machine worked perfectly the whole time!
Sorunome (author)2010-09-08
Pic 9 and 10 have to be swapped!
Tornado96 (author)Sorunome2010-09-08
Oops! :-P noone really noticed before so I'm sure it's not that much of a problem.
Sorunome (author)Tornado962010-09-08
;-P
Shadowman39 (author)Sorunome2013-07-24
Now I've seen another place where you use a smiley with a nose! Yay!
Sorunome (author)Shadowman392013-07-24
lol :P
omigosh you used a nose!
I don't know why I used a nose, I must have been cunfused. :D
héhé >:-)
Tornado96 (author)Sorunome2010-10-11
:-D
Sorunome (author)Tornado962010-10-12
Oh... that took long. :)
Tornado96 (author)Sorunome2010-10-12
sorry. :-P
NP ;P
Tornado96 (author)Sorunome2010-10-13
Sorunome (author)Tornado962010-10-14
:) Smileys without noses rule!! ;P
Tornado96 (author)Sorunome2010-10-14
NO MORE SMILEYS ON THIS IBLE PLEASE.
Shadowman39 (author)Tornado962010-10-16
:-D
Tornado96 (author)Shadowman392010-10-17
HEY!!!!!
Sorunome (author)Tornado962010-10-17
Invasion of smileys! :) :)
Tornado96 (author)Sorunome2010-10-17
Sorunome (author)Tornado962010-10-18
Of course is the invasion is of smileys without noses! :) :)
RNB (author)Sorunome2010-10-18
No. Smileys with noses! :-ß or ß-)
:-) :-( :-P :-O 8-) :√) (mathematic smiley!)
Sorunome (author)RNB2010-10-19
Smileys mithout noses RULE :)
Tornado96 (author)RNB2010-10-18
:-D NOSES! I did the mathematical one on my calculator a few weeks ago. :-D
Tornado96 (author)Sorunome2010-10-18
Sorunome (author)Tornado962010-10-15
OK
Bolts#13 (author)2012-07-29
Really cool design u have created.
Knex1235 (author)2011-12-13
do you need that motor i have a different one can i use that
Tornado96 (author)Knex12352011-12-22
It may work. Try it out!
2800th Cooment! :D
can you use yellow connectors for the path??
knexpert#10829476 (author)2011-10-05
Nicely structured and it is very durable:-)
haha cheers!
fredboekel (author)2011-07-15
i love your ball-machine i made it ent is cool
Tornado96 (author)fredboekel2011-07-15
thanks!
k-n-e-x(leaved ibls) (author)2010-12-11
somebody hacked me so i can't rate 5 * on all of your ibls....
:-P. Can you now?
no i can only rate down
:-( Just make sure you don't do it ;-)
only if you rate at my ball machine project 3
THat's no way to treat a friend... >:-(
lol i don't rate down i'm not crazy
good... Happy new year!
HAPPY NEW YEAR 2011
Thanks you too
Tornado96 (author)2010-11-05
WHO MADE IT LESS THAN FIVE!
RNB (author)Tornado962010-11-07
Don't worry, I just pushed it back to five. :-)
About This Instructable
5,972views
11favorites
License:
Bio: I'm a 16 year-old guy who loves to build mechanics out of knex. my main interests are ball machines and roller coasters. My real ... More »
More by Tornado96:Knex Ball Machine: UprisingKnex Alternating Arm LiftK'nex Semi-Circle Lift
Add instructable to:
