loading
Step 3: Install the Sansa firmware updater.
Go to http://www.sandisk.com/Retail/Default.aspx?CatID=1376 and install the Sansa View firmware updater. After you install the updater you might need to restart the computer. After your restart the updater, connect the Sansa View to the computer and it might automatically recognize the Sansa View and show you your firmware and the up-to-date firmware. If that happens check the updates you want and hit the update button and you'll start to upgrade your firmware. If your computer doesn't recognize your Sansa View then you have a problem, a pretty big one. Don't worry, if you do this instructable right you might get out of this without a hitch.
Hey, I was having problems getting the view to work on Vista. Easy solution: go to the folder "More", then "Settings", then "USB Mode". Change it from "Auto Detect" to "MSC". Done! Worked fine.
Yes that is because you had the right firmware. The earlier versions of Sansa View did not have an MSC mode.This instructable tells you how to manually enter MSC mode and download the updated firmware using Vista if you have an older firmware.
About This Instructable
8,053views
4favorites
License:
More by Solderguy:How to extract Wii games to your computer using a usb stick. How to play Wii backups from a usb stick with no modchip. How to play Gamecube backups on your wii without a modchip.
Add instructable to:
