This instructable has been removed by the author.
29
comments
Add Comment
nice ladder!
This looks like a great project; I cant look at the design and figure out exactly how it works, but somehow it does. Without knowing how the cores of the xfmrs are wired - like what type of xfmr it is, being 2-core wound, buck/boost, etc, I cant really guess. I'd love to see some voltage and current readings, and for gods sake ground these transformers to the mains ground (NOT neutral. Just because the neutral is connected to ground doesnt make it ground! In 1-phase the neutral isnt a neutral, is a return path and can still give you full voltage.
If he ran to the mains panel and ran off a breaker that had 2-poles, that would be 2-phase (2 phases into most homes with a neutral, each breaker slot alternating what may be called "A" and "B" phases. Look at a new circuit breaker panel in the store, you'll see what I mean).
I'll be sure to watch what this guy has coming up next. I see a mad scientist developing here. Good luck & stay safe. Dont get "grounded" lol.
You could do the same thing as you have done here by using a neon sign transformer. The center tap is already grounded to the case. Just hook your center electrode to the case. The NST has the advantage of a current limited secondary.
If i could feature this instructable, i would.
