loading
After Searching for so long for a pattern that I couldn't find, I decided to try and make my own. After 4 hard and frustrating attempts, I managed, I think it turned out pretty well. So here I am... Ready to share this tutorial with you! Hope you Enjoy it!
For this you Will NEED:
Perler beads
-Chedder
-Yellow
-Brown
-Light brown
-Orange
-Random colour for bottom (Colour you dont use that much and wont miss if used up)
The bottom is optional, you can do it black but I chose to do it Blue because it was a colour i didn't use often, and i wouldn't miss it if it were gone.  I didn't use brown or black because I use those too much and you cant see the bottom so it would be a waste.
You will also need:
-Ironing Paper
-Iron
-one LARGE Square pegboard
*Optional* Tweezers
Step 1: How to make a 3D Mario box part 1
Here is the pattern.
Step 2: How to make a 3D Mario box part 2
This is the other three Sides!
Step 3: How to make a 3D Mario box part 3
Ironing!
When Ironing the sides make sure you go in a circle motion, Only iron for 30 seconds!
* DO NOT OVER IRON!*
if you over iron the beads will not lock together! you DONT want the holes to close completely,
once thats done flip it over and iron again for 10 seconds just to give it strength!
Place all the pieces under a Flat heavy surface so they do not bend! this part is very important!
Step 4: How to make a 3D Mario box part 4
Piece the pieces together, it's like a puzzle but they should go together with ease.
This tutorial is great! I made two coin banks, one for me and one for my brother and we both love it. I doubled the size as I wanted to be able to save lots of bills and coins. The size of each block side 6" × 6", and it it really spacious when the whole thing is put together. It does require alot of beads to up the size (4 perler beads for each one used in the original pattern), but once I got working I seemed to zoom through making it! Took about 3 days total to make both, working off and on. I would recommend this pattern to anyone who loves mario and I've even used it as a basis to make a 2" block keychain, with some manipulating.
I forgot to add, doubling the pattern makes the bank about 4 times bigger than the original pattern just for reference. And if you over iron and the sides won't lock, you can take an exacto knife or boxcutter to trim the black pieces until they fit snuggly. I did that for both boxes because I like a more melted look.
<p>super awesome this uses alot pf black so i ended up running out i used gray for the explamation mark and the brick cememt and clear for the rest of the attachments it works great as a coin bank too!!</p>
<p>This looks great! I have been looking for a way to DIY a mario themed wedding card box.</p><p>I do have a couple of questions though... approximately how big is this? It's a little hard to tell from the photos. Also, it looks like the pattern is just photos - do you have more detailed instructions for the pattern (like, X brown beads, X black beads, etc) or do I just have to guess based on the pics?</p>
Hi heather! Sorry for the late reply. This box is small and will not fit a card. You could double the size however. The patteren is the pictures above, you would just go back that. I didn't count how many heads were needed as I just buy individual colour packs with 1,000 beads!
<p>Super easy, thanks for the awesome pattern! for the record this took me about 2 hours, but a big chunk of that was fishing out enough yellow out of my random bucket o'colors.</p><p>I left my iron in the picture for size comparison</p>
Yeah it's super simple! My biggest issue with the first few attempts was over ironing, &amp; not being able to lock the pieces together!
<p>can you make it bigger and still use the same clip on options ? im making one with Mario but Mario is 16x16 squares/ I made one already in your 15x15 squares but I want to do one with Mario... he happens to be bigger... can I do one 18x18 or 17x17 .. would the side clasps be the same as this one.. have the 18x18 square done but the claps don't fit all the way ... wondering how to fix this</p>
Hey! Sorry for the late reply! I think you could make it bigger, just double the pattern! It should work out as long as it's an even square!
<p>A pretty simple pattern. I swapped the top block opening from vertical to horizontal for my own preference, however a fun project! I ran into difficulty when it came to putting the pieces together as a few sides clashed, however I was able to cut and replace the beads to fit together. The overall block is durable and requires no glue for reinforcing. Would recommend and I thank the original poster for this project! </p>
<p>Can you use it like a coin bank and take the bottom off or is there a way to do that?</p>
<p>This is a great idea!! My little brother loves Mario, and I feel if I make it for him he will love me forever!!!</p>
<p>This is fantastic! Best tutorial for a perler bead box on the interwebs! :) Thank you!</p>
<p>Hey there, few questions for you. First off, great instructable! Now, I was thinking of using your design to make some lamps for around my home. About how big are these? Also, I see the text &quot;Here is the pattern&quot; between some pics but no link. Was there a pattern or do I just need to figure it out from the pics? </p><p>Again, I was thinking of using these for lamps somehow (perhaps modifying one of those standing lamps). Hopefully I can make it work. Thanks again for this great project!</p>
That looks like it took a long time to make
This is way too cool! Definitely going to make some for Christmas for my friends!
I have a strange, unrelated question for you. How did you seperate your first picture into four little pictures? Is it a particular photo software program? I'd like to do &quot;before and after&quot; pictures.
Www.picmonkey.com on the Main page click &quot;make a colloge&quot; no downloading needed.
Thanks!
Oh! Oh! How about a Minecraft chest coin box!!
I'll try! :D
This is awesome. Maybe the best use of those beads I've ever seen. :D
Thank you! xD
About This Instructable
80,287views
249favorites
License:
Bio: short, crafty, cool, nerdy, awesome, everything you wish you could be. Im kidding, I am cool though. ;)
More by Coolnerdgirl:How to make a Piranha plant with a tube How to make a 3D Mario Coin box!
Add instructable to:
