How to Make a 9 Volt Battery Adapter
12,248
26
8
Posted
Introduction: How to Make a 9 Volt Battery Adapter
hate trying to use 9volt batteries for your projects because you cant connect wires to it
well here is a simple way to make a 9 volt battery adapter.
Step 1: What You Need
- A 9 Volt battery (you can use a dead or a working battery if you use a working battery I will show you how to not waste the energy still in it)
- 10 gage  wire
- A soldering iron
- Solder
- A multi-tool
Step 2: Step One
You will need to get into the 9 Volt battery by baking the cover off of the battery with your multi-tool
Step 3: Step 2
once you have the piece you need you are all ready to solder
if you don't want to waste the rest of the battery if it isn't dead  you can use the pink cells as AAA batteries
first you will need to cut them out of the protective plastic and unwind them
then you will need to rip them apart and now you have 6 AAA batteries
Step 4: Step 3
you will now need to cut your wire    you need 2 pieces about 5 inches long
now you need to strip the ends and solder them to the back of the metal terminals
Step 5: Finished
you now have a 9volt battery adapter that you can use for you projects instead of going out and buying one
If you liked this project check out some of my other projects and follow me,
thanks
and please vote
    • Science of Cooking
      Science of Cooking
    • Pocket-Sized Contest
    • Spotless Contest
      Spotless Contest
    8 Comments
    nice one defiantly gonna help me with mini projects
    I noticed you usually photograph against a white shag rug. Don't you worry about getting it dirty?
    Thanks for the instructable. Very informative. One small point - I believe the cells inside are called AAAA rather than AAA. That means they are a little smaller.
    ya your right but you can use them as AAA's
    I just didn't want to confuse people because most people don't know what AAAA batteries are
    thanks for the heads up
    amazing i will make this as soon as possible!!
