How to Make a Arduino Digital Clock
13,322
28
83
Posted
Introduction: How to Make a Arduino Digital Clock
Digital clocks are one of the great invention in the field of science.
Have you ever wondered "How to make your own digital clocks , just like in movies! "????
Well i have also spent ,my childhood in a dream to built my very own digital clock.. so i built one for my self ...
And am going to show you, How you can built an amazing digital clock with little ease and little components all by yourself....
I have used 4 7 segment common anode display to display the digits, 3 SPDT switches , which i took apart from an old mouse, some wires and an arduino. we can set the time holding the adjust key and pressing the minute or hour key to change the minute or the hour to our need..!
So Lets get started...!
Step 1: Components Required
Here the Components that you will Require :
1. An Arduino uno.
2. 4 7 segment common anode displays (if you have a 4 digit seven segment , don't worry the circuitry is same for both of them).
you can buy them from snapdeal , they are great ! i would recommend them from the site.
3. 3 spdt Switches (which i scavenged from an old mouse ).
4.some wires and jumper wires (any one will do!).
5. A breadboard.
6. 4 1kohm resistors.
Step 2: Wiring the Displays in the Breadboard!
Make the connections as shown in the picture above.. its quite simple.!
Take care of the connections , as coz there are too many wires you might get confuse.
Remmenber All a,b,c,d,e,f,g,dot segments of 4 displays are connected together.... and the com of every display i.e 3 and 8 are connected together with the resitors...
Do not worry!! , go slowly,and have some patience , you can do it.
Step 3: Adding the Resistors and the Keys
Attach 1kohm resistor with each com of the displays ... as shown in the figure..!
Add the Spdt switches or if you have push on buttons that would be great !...
Step 4: Connecting to Arduino
Now the connections are done for the display and the switches ... now time is to connect them to the brain..
it is simple..
For segment pins!
a to pin 2
b to pin 3
c to pin 4
d to pin 5
e to pin 6
f to pin 7
g to pin 8
dot to pin 9
For display pins
display 1 to pin 10
display 2 to pin 11
display 3 to pin 12
dispaly 4 to pin 13
now for the keys
key 1 which is the adjust switches ...
key 2 and key 3 are hour changing and minute changing switches..
we have to hold the adjust key1 and press the desire key to change the hour or the minute..!
see the pic above for the connection for the keys .. we have used the analog pins and used them as digital input pins... yes thats true we can use them as digital i/o pins too..
Step 5: Adding the Code!!!!
Now the most cool part ... writing and adding the code to the arduino....
I have attached the code and the time library file .. for calculating the time and displaying it....
In the code the hour() function tells us the hour, and the minute() function the minute , from the time we have switched on the board. the time fades dies when the power to the board is cut of.. and it starts again from 00:00 every time...
Also i have attached a 12 hour format code too. It just uses hourFormat12() function to get the 12 hr format.
By default the Time library returns 24hr formated time.
Note:
Please add the Time Folder in Time.zip, in your Arduino's libraries folder.
eg in my system:
C:\Program Files (x86)\Arduino\libraries
Do feel flexible in changing the code for your needs ... and if you have some quarries feel free to ask.
Have fun making it...
note: I have updated the Time.zip file as it was deprecated in newer versions of Arduino IDE.
  • Science of Cooking
    Science of Cooking
  • Microcontroller Contest
  • Spotless Contest
    Spotless Contest
2 Questions
Error: 'hour' was not declared in this scope
that is my error help me please i tried everything i read in the comments for the same problem but nothing happened. please help
64 Comments
how can i convert this 24 hours digital clock code to 12 hours format???
Or can you give me the 12 hours format digital clock code for this same diagram????
Madrajib is it a 24 hour clock
Yes , Ed Marjosef.
how to convert it 24 hours to 12 hours formate sir????
Dear Sir,
I have a letest arduino version software and I have follow of your instruction and i have alredy connect breadboard to arduino wires of your instruction.When i have download of your first link Sketch file and open in arduino but upload not properly.I dont know any technical problem show here.Please tell me How to upload directly without any programing.Thank you sir.If you want E-mail me for sending any code Sketch file please send (ayandeysarkar76@gmail.com).I likes your videos every time....I hope you understand and I wish you are help me for this problem journey.Thank you.
Show less
Hour was not decrared in this slope ...please help me out...??
Sorry RajA46 for such an late reply and error. actually the Time library i have used was for old version of arduino ide. it was update after arduino ide 1.6.1 version, hence the error.
here is the link to new updated library, but before you use it delete the Earlier Time folder from libraries folder
C:\Users\lenovo\Documents\Arduino\libraries and also from
now dowload the zip file and add it to arduino,
https://github.com/PaulStoffregen/Time.git
To add it go to sketch->Include Library->Add .Zip Library and find the zip file.
after that go to sketch->Include Library->Time
And it will work.
yeah i have the same problem too. pls, i really need your help, hour is not declared in the scope
