Remove these ads by
Signing UpStep 1: What the heck is a bogota rake, and why do I desperately need one?
A bogota rake is a special variety of lockpick designed by a brilliant lockpicker by the name of Raimundo. He named the pick after the bogota mountains, because of their sharp peaks and rounded valleys. A rake is a term used to describe a lockpick that has peaks and valleys, and is used to manipulate the pins in a lock by 'raking' (moving the pick in and out) against the pins. A bogota rake is used slightly differently, described by Raimundo as a “jittery motion”, as though the user had consumed too much coffee.
If you are planning on making these, I will assume you know how to pick a lock already, if not, checkout youtube and search for bogota rake.
Take a moment to look at the template above. The advantage of a bogota rake may not be immediately apparent, but using one will make you a true believer. The speed at which most common pin tumbler locks fall prey to this set is extraordinary.
Visit Our Store »
Go Pro Today »
I need to build a deadbolt rig and practice more with my set. So far I've only been successful at my house.
Also, DIY bogotas always make me think of the BIGGOTA I made for MBI over at Keypicking as part of a novelty pick set I did for him (The lightning bolt is pretty cool too.) There is a pic of it in the following thread over there: http://keypicking.com/viewtopic.php?f=39&t=5410
