3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
How to make a Cardboard Box from recycled cardboard
Step 2Draw and Cut
Draw and Cut
decide the size and dimensions of your box, I usually just draw the bottom part first to see how big I want my box to be, and then I would measure the dimensions of it. After that I would draw the side pieces make sure 2 of the sides are the length of the bottom side subtract the thickness of the cardboard (about 1/16 of an inch each, so 1/8' total) for example:
if the bottom(base) is 3' by 3' you would cut 2 of the sides 3' by 2'(height of your choice) and the other 2 side you would cut 2' and 7/8'(3'-1/8') by 2'
of course different cardboards have different thickness, so i suggest that you draw and cut the base first and glue them together(in the next step) and then measure the thickness, then come back to this step and finish cutting the rest of the sides. and don't forget to double the thickness of the cardboard.
I hope that make sense.
okay after you got that down you need to draw and cut 3 of each piece so total there would be total of 15 piece of cardboard.
(if the cardboard is already pretty sturdy and thick, you could just do 2 of each piece, so total of 10 pieces)
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:xxk4r3nxx
